Starter issues
Old Apr 11, 2024 | 05:02 AM
AuroraGirl's Avatar
AuroraGirl
Originally Posted by rla2005
The 4.9L uses a crimp on lug for the ground point at the starter bolt. Seen more than a few grow corrosion there or simply loosen over time. That was my reference to poor design.
I cleaned up my alternator mounting bosses , and my new alternator, and the bolts, then used a bolt to bolt a lugged cable to the rear of my 3g alt. this is an easy way to improve the 4.9 engine ground without having to even touch the starter one. the starter one is also thin gauge and is part of the one that daisy chains, unprotected and exposed wires, to the frame rail nearby. rusty usually.
Old Apr 11, 2024 | 12:38 PM
Hit Man X's Avatar
Hit Man X
Perhaps I will move to the block then as I need to reinstall my starter anyway on the 4.9 or just add an additional ground.
Thanks for heads up.
Mar 28, 2023 07:16 PM
darrelgiv
Jul 19, 2011 09:31 PM
joewaldner
39
Feb 13, 2008 11:29 AM
dracip
Jan 28, 2008 06:43 PM
Mulletwagon
Electrical Systems/Wiring
Aug 6, 2001 04:08 PM
