Hate to do it but...
Old Apr 1, 2024 | 12:53 AM
  #61
bentring's Avatar
bentring
I linked to these guys already who have done several trucks...
Old Apr 1, 2024 | 01:02 AM
  #62
4wd6.7L's Avatar
4wd6.7L
https://www.youtube.com/watch?v=SIV4DukAKdM
.2wd......
Old Apr 1, 2024 | 02:44 PM
  #63
Johnny F2 fiddy's Avatar
Johnny F2 fiddy
Originally Posted by 4wd6.7L
The most economical way would be to get a 2wd truck, possibly not a Super Duty. The 4wd Super Duty only has about 1-2" of travel before you are sitting on bump stops, no way to get a 6"-8" drop out if it. I'm not familiar with the 2wd Super Duty front end.
Boy, if that were true, my truck would be riding on the bump stops every time I hook up my 5th wheel.....not even close to being an accurate statement!
Old Apr 1, 2024 | 02:47 PM
  #64
4wd6.7L's Avatar
4wd6.7L
Do us a favor, go take a picture of your front bump stops then (the space between them and axle)......we'll see just how inaccurate my statement is.
Even though the OP has a SRW, and yours appears to be a 450, still interested in your findings.
Old Apr 1, 2024 | 03:12 PM
  #65
Disarray's Avatar
Disarray
OP, your best bet is to go with an adjustable suspension system with airbags. My wife's Grand Cherokee has four corner suspension and can lower itself 3 or 4 inches to make getting in and out much easier. If you wanted to go super low, you would have to notch the front and rear frame rails and hope there are no interference issues in the front suspension with the track bar, steering, and sway bar. The rear suspension would have to be converted to a link system like the Kelderman setup since leaf springs will likely only go so low before their spring rate overcomes cargo weight and stops.
Another option would be Liquid Springs, but that is a pretty pricy setup, and you will still probably have to go to a link style rear suspension.
Old Apr 1, 2024 | 03:20 PM
  #66
CheeseheadFord's Avatar
CheeseheadFord
I've seen vans with ramps that come out of the side of the door, could something like that not be done here? Maybe that along with lowering the truck as much as possible without extensive upgrades under the truck would get the OP where he needs to be?
Old Apr 1, 2024 | 04:35 PM
  #67
twobelugas's Avatar
twobelugas
I believe he is right, my front suspension on a 4wd stock has very few inches between the bump stop and the perch on the axle. The bump stop may allow some compression on very sharp impact but it won't give much on a static load if something like an air suspension system lets air out to lower the whole truck
The amount of travel on the rear is less relevant since the driver's seat is right behind the front axle and that's where the lowering matters.
azmiller
Sep 13, 2023 08:17 PM
lknight
Offroad & 4x4
Jun 27, 2022 06:29 AM
pat67shorty
Jun 13, 2017 09:38 PM
sh1520
Sep 20, 2007 03:07 PM
