2wd Super Duty?
Old Sep 12, 2023 | 02:15 PM
azmiller's Avatar
azmiller
2nd Gear
2wd Super Duty?
I am interested in buying a new or relatively new 2wd Super Duty. There is not much information out there regarding 2wd Super Duty trucks. Is the independent front suspension a good system on the Super Duties? Does anyone have first hand experience with a 2wd Super Duty?
Old Sep 12, 2023 | 02:40 PM
KU4OJ's Avatar
KU4OJ
Yes. Where I live I have no need for 4WD. Others do, that's fine, but I do not. 2WD makes for an excellent ride, easy to drive low maintanance tow vehicle. There is NO drawback to 2wd.
Provided you stay out of where you might get stuck.
Old Sep 12, 2023 | 02:48 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
I have a 2022 2WD F250 Lariat 6.7 PowerStroke.
I buy 2WD because mine never goes off road, mine is about 99.99% highway, and half of that towing.
It will be the last 2WD Ford because Ford now only sells 2WD super durty's in base XL trim, XLT and higher trim are now only available as 4WD.
If you want to buy one, I might be interested in selling mine.
Old Sep 12, 2023 | 03:04 PM
'65Ford's Avatar
'65Ford
Ford has used the twin i-beam in 2wd's since 1965. It's a good system...durable and good handling in a pickup. And I've never heard of a twin i-beam having the dreaded "death wobble".
They use ball joints like most cars and pickups which need replaced somewhere past 100,000 miles.
Old Sep 12, 2023 | 03:07 PM
Louisville Joe's Avatar
Louisville Joe
Twin-I-Beam is good for wearing out front tires. It's durable and does not have 'Death Wobble', ride is good but does not handle all that well (drive a newer 2WD GM HD truck for comparison). Ford only offers 2WD on XL fleet trucks now, all other trim levels offer 4WD standard. Good luck finding a 2WD Super Duty.
Old Sep 12, 2023 | 03:18 PM
CR172's Avatar
CR172
I think Ford is making a big mistake with only 4wd on SD's.
Old Sep 12, 2023 | 03:30 PM
DPelletier's Avatar
DPelletier
Pros and Cons just like most things;
2wd Pros:
- cheaper to buy
- cheaper to maintain
- lower center of gravity for easier loading and improved sway control
- lighter weight for increased payload and improved performance
2wd Cons:
- far easier to get stuck offroad, in mud, snow or wet grass
- lighter weight on the front axle may be a negative for bumper pull trailers
- lighter overall weight makes it a bit easier for the trailer to "wag the dog".
- Only available in an XL trim level
- may be hard to find and sell
I can totally see and agree that a 2wd would be a better choice depending on usage and local. For me, I need 4wd just to get up my driveway in the winter.
2 cents,
Dave
Old Sep 12, 2023 | 03:43 PM
Joe T's Avatar
Joe T
I have had 2 and I like them. The gas motor has a lot of traction control nannies even with advance trac off. The diesel is a little more liberal and won’t get you stuck in wet grass.
About to put my 2020 2wd loaded STX 6.7 dually on ebay, if you want it let me know.
Old Sep 12, 2023 | 03:55 PM
'65Ford's Avatar
'65Ford
A few non truths here...
- Accelerated tire wear may have been a problem back when twin i beams used king pins and had to be bent for alignment but not with ball joints and relatively easy adjustments.
- 2wd is plenty heavy enough in front to tow anything
- "Wagging the dog" is when a trailer pushes the rear around, not the front.
- With proper tires and a little weight, 2wd will handle snow up to its axles. And tire chains can be added where required or stay home. Lot of guys add weight to the bed of their 4wd, btw
- Also, with proper tires 2wd will handle wet grass just fine. I've heard lot of folks say they have trouble in grass without 4wd...but for pete's sake...that's ridiculous. I've done too much 2 wheeling in pasture fields to believe that.
Old Sep 12, 2023 | 04:03 PM
Joe T's Avatar
Joe T
Um no, even with advance track off it kills the motor as you get momentum in wet grass, thus digging a hole. Absolutely will not allow wheel spin above about 5-10mph while moving. Absolutely will do nothing but force it to get stuck, its absolutely programmed to get you stuck. I would ****ing kill the engineer who designed the traction control system in a 2wd 6.2 f250 and his first born if it wasn’t illegal.
Been stuck in wet grass, sank in sandy lomb and got pulled out with a dodge with baby *** smooth bald tires at 2am after getting stuck in wet grass 50 miles from home. Absolutely no exaggeration.
Literally I would kill the ****er.
My 2020 6.7 2wd is a little more liberal and its a dually as well. I have been able to get through some nasty wet fields in it, with street tires as well.
Long story short if you get a gas 2wd single rear wheel you will be putting an ABS switch in it. The poster above doesn’t know what he is talking about.
Old Sep 12, 2023 | 04:09 PM
Joe T's Avatar
Joe T
And that 2wd gas truck had BFG ATs on it that were in good shape.
I damn near burned it that night. POS
Old Sep 12, 2023 | 04:18 PM
'65Ford's Avatar
'65Ford
Ha ! Well you got me there. I've never driven one of the newer "smart" trucks. Add this to the reasons I don't want a new truck. Sounds like you're talking about the built in (required by law) stability program. Can't you temporarily turn that off with a button?
Though I think I would have at least looked for a way to pull the plug on the ABS if that's all it takes before I let myself get stuck in wet grass. Btw, unless I'm backing up a hill I don't spin on wet grass... unless I'm trying to spin...
Old Sep 12, 2023 | 04:49 PM
Charlie98's Avatar
Charlie98
I agree. My truck is my work truck, but it's also my 'station wagon' if you see what I mean. I don't need 4WD... but I got it, now... along with more expensive insurance, more maintenance and upkeep, and a harsher ride. I didn't really want to have to go completely ghetto with an XL, like my 2009, to keep 2WD when I went shopping for my '23... so I got what I got.
FWIW, I have had 2 2WD SuperDoodies... a '99, and I still have my '09. I sold my '99 at 186K, and my '09 has 208K on it... and I've never touched the front ends, besides brakes. Like every coil spring front suspension... they will eventually start to sag, my '09 is there, now; it's not clapped out, but you can tell the coils are tired. Having said that, I've never had problems with irregular tire wear, or any sort of steering anomaly. I like the twin I-beam, but I liked my 2500HD 2WD torsion bar front end better.
Old Sep 12, 2023 | 04:54 PM
Charlie98's Avatar
Charlie98
True story. 2WD crew cab up in the Colorado mountains, about 11000ft. I was pushing snow with the front air dam by the time I found a spot to spin it around and head back down... discretion is the better part of valor. A bit of weight, a judicious gas pedal, and a little patience... along with good tires... can get you a lot of places. More importantly, it can get you OUT of a lot of places.
Old Sep 12, 2023 | 05:03 PM
Billn59's Avatar
Billn59
I ordered a 24 Lariat and wish it came in the 2WD. I just want to tow on paved roads and occasional gravel roads. Would prefer to have the extra payload.
