rf capacitor?
Old Mar 24, 2024 | 12:30 PM
Fordnut75's Avatar
Fordnut75
8th Gear
rf capacitor?
Hello all, I've tried search the threads for this part with no luck. It has e7tf 18801-aa 648 on it. Located near the ignition coil. What does this do?
The issue I am having is that my truck (94 F250 5.8l) will start when its warm but will only pop and fire just a bit when colder. I checked fuel pressure which was low so replaced the fuel pump, also had a bad fuel pressure regulator, replaced that. Tries to start a little better now but wont run when cold.
The reason I'm asking about the above mentioned part is that I had the truck transported from AZ to SD and noticed that the wire to that is broken off. It ran great before the transport.
Any help would be greatly appreciated.
Old Mar 24, 2024 | 01:55 PM
My4Fordtrucks's Avatar
My4Fordtrucks
(Ignition) noise suppression for the radio.
So what fuel pressure do you have after replacing the pump? Are they any KOEO fault codes?
Old Mar 24, 2024 | 02:08 PM
Fordnut75's Avatar
Fordnut75
8th Gear
So that part has nothing to do with ignition? It has 38psi for fuel when i turn the key on , holds pressure when i turn the key off which is my understanding that regulator and injectors are holding pressure . I havent pulled codes, not sure how to do that exactly. i think i can figure it out though, ill go pull them and see what they say.
A little more info, the truck started 2 days ago and ran fine temp was in the 40s now wont start in the 20s
Old Mar 24, 2024 | 02:20 PM
My4Fordtrucks
No. Have you determined what you are missing: spark or fuel?
Old Mar 24, 2024 | 02:30 PM
Fordnut75's Avatar
Fordnut75
8th Gear
i think i have the codes i got 116 ,636, 114, and 654. Im sure I have fuel now that the pressures are good. I've also hooked a timing light to each plug wire to see if each one is firing consistently when it does run.
Old Mar 24, 2024 | 02:55 PM
My4Fordtrucks
116: engine coolant temp higher or lower than expected
636: transmission oil temperature higher or lower than expected
114: air charge temp sensor higher or lower than expected
654: not in “park” during KOEO self test
Was the truck up to operating temperature when you ran the test?
Old Mar 24, 2024 | 02:58 PM
Fordnut75's Avatar
Fordnut75
8th Gear
No it wasn't, wont start today.Trying to get a video of what its doing
Old Mar 24, 2024 | 03:32 PM
Fordnut75's Avatar
Fordnut75
8th Gear
I can't get a video to work. Fuel pressure never goes below 35 when cranking, it will run for a few seconds then die. After about 3 tries of starting it will backfire a bit but not start .If I let it sit for a 1/2 hour or so it will run a few seconds again.
Old Mar 24, 2024 | 03:37 PM
My4Fordtrucks
Ok. When it won’t start do you you have spark?
Old Mar 24, 2024 | 03:39 PM
Fordnut75's Avatar
Fordnut75
8th Gear
Yes, it will fire but not stay running for longer than 3 seconds.
Old Mar 24, 2024 | 04:21 PM
My4Fordtrucks
So do you not have fuel or spark when it stops running?
Old Mar 24, 2024 | 08:32 PM
Fordnut75's Avatar
Fordnut75
8th Gear
It acts like its out of fuel.
Old Mar 25, 2024 | 06:44 AM
My4Fordtrucks
You need to confirm which one.
Old Mar 25, 2024 | 08:13 AM
manicmechanic007's Avatar
manicmechanic007
If that ignition noise suppressor capacitor shorts out, you will have no spark
You can find them online NOS
Old Mar 27, 2024 | 05:39 PM
Fordnut75's Avatar
Fordnut75
8th Gear
The suppressor did arc when the wire came apart which blew a fuse, I replaced that and it has ran since then just not well. I had a similar issue on a 6.0 in an F450, that turned out to be the diode in the fuse box under the hood. I've got one ordered for this truck, not exactly sure what it does but for 9 bucks im willing to try it. Ill keep digging to see what is failing spark or fuel. Thanks for the help so far.
Banjo250
1997 - 2003 F150
18
Jul 2, 2019 04:29 PM
78ihs2
May 31, 2019 12:04 PM
econoshorty
Jan 2, 2011 07:42 PM
dantm
Nov 23, 2010 02:43 AM
Race4Fun
25
Sep 29, 2009 05:57 AM
