Can't find block heater
Old Mar 8, 2024 | 11:06 AM
Grinkle's Avatar
Grinkle
5th Gear
Hi, all.
I recently bought a used 2019 F-350. I printed out the original window sticker from Car Fax to assess the build. Engine block heater is on the options list. I searched it, and the video's I found indicate there should be a plug on the lower-front facia. I don't find a plug there. I can see a wire harness that runs horizontally along the facia, but its tie-wrapped along the facia and I can't find any loose hanging harness that would be the plug as I saw in the videos.
Am I possibly wrong about what that option means on the window sticker, or should I check somewhere else for the plug?
Thanks in advance for any help.
Old Mar 8, 2024 | 11:10 AM
redford's Avatar
redford
FTE Leadership Emeritus
My 2019 block heater plug is tucked up in the passenger side fog light recess.
Old Mar 8, 2024 | 11:19 AM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Inside behind the bumper on the passenger side.
Old Mar 8, 2024 | 11:25 AM
99powerstrokedF250's Avatar
99powerstrokedF250
These guys have it right, if it's still there it's on the passenger side hidden away.
There is also the possibility that it was removed, though I have no idea why someone would do that.
Old Mar 8, 2024 | 11:26 AM
2021F350's Avatar
2021F350
Originally Posted by Grinkle
Hi, all.
If it hasn't been used it's not loose... It's rolled up taught and strapped just to the passenger side of the license plate...
Old Mar 8, 2024 | 11:40 AM
Pugga's Avatar
Pugga
Start at the heating element and chase the wire to the end. The element is visible through the passenger wheel well. Here's the element, confirm it's installed and chase the wire.
Old Mar 8, 2024 | 05:07 PM
mtnguy's Avatar
mtnguy
My 2017 shows itself at the passenger side tow hook area.
Another thought. There was a recall on the block heater. Before Ford had enough parts, they had dealers cut the harness so it couldn’t be used.
Old Mar 8, 2024 | 06:07 PM
morehouse7's Avatar
morehouse7
Yes, I brought mine in and they replaced it. Then they called not too long after and said that they had to have it back to remove it, I never took it back for the removal.
GreatWhite99
Jan 5, 2010 09:28 PM
Demolition
6.4L Power Stroke Diesel
18
Nov 1, 2008 08:49 PM
blackhat620
Jan 30, 2004 08:57 PM
shendren
Jan 13, 2004 08:48 PM
CHACH
Nov 8, 2003 10:11 AM
