BAD Block Heater???
Old Jan 5, 2010 | 07:38 PM
GreatWhite99's Avatar
GreatWhite99
BAD Block Heater???
Well my block heater is not working, i have tried two different extension cords and two different outlets (non-GFI), can i just replace the cord that runs to the block or would it be sumthing else wrong????? thank you
Old Jan 5, 2010 | 07:45 PM
big poppa's Avatar
big poppa
Ussually its the plug connection that gets corroded or the plug itself, start there and work your way back checking for cracks and such. If its the plug, you can spice another one in its place.
Old Jan 5, 2010 | 07:53 PM
GreatWhite99
OK Thanks for the help, i will look at it 2mrow, if i do have to get a new one should i just go to Ford or does sumone else sell them??
Old Jan 5, 2010 | 08:39 PM
Ponyboychris's Avatar
Ponyboychris
Just get a replacement three prong plug from Home Depot or Lowes. cut and splice. They usually crack right behind the OEM plug.
Old Jan 5, 2010 | 08:41 PM
big poppa's Avatar
big poppa
Just your regular hardware store or Home-Depot or Lowes, make sure you get one rated for that type cord, not sure what the voltage rating is off hand for that cord but somebody will be by to tell you..^^what Chris said above.
Old Jan 5, 2010 | 09:18 PM
Vinford's Avatar
Vinford
I bought a whole new aftermarket cord for $14.00 at Napa.(I think)
Old Jan 5, 2010 | 09:28 PM
guitarpicr's Avatar
guitarpicr
Probably 16 gauge wire should be heavy enough.
mblayton
Ford Truck Parts for Sale
Jan 9, 2017 05:53 PM
ralf12
Dec 28, 2016 03:18 PM
FarmingF250
Jan 4, 2016 07:29 PM
LOADED 06 PSD
Nov 26, 2012 08:34 PM
drivembig
17
Jan 11, 2010 04:36 AM
