6.0 whining noise when accelerating
Old Mar 1, 2024 | 11:53 AM
04-6.0 BinkBink's Avatar
04-6.0 BinkBink
5th Gear
Im new to diesels. I have had a 6.0 powerstroke for 2 years now. I just had to have the EGR replaced with BPD and oil cooler replaced. The diesel shop call and wanted to changed the HPOP while they were in there but were going to double labor. $4300 for oil cooler and EGR, 8k for oil cooler , EGR and HPOP. Anyways I said no. I have a scan gauge and delta were like 14-16 for a while so I knew that was bad at least. HPOP 580, IPR 22, ICP 17 all at EOT. WOT HPOP 3300, IPR 72 %. Anyways there has been a whining noise which is NOT new. The whine gets louder on first acceleration, not a squeal but more of a winding sound like when you put a manual honda in reverse just not as loud. At one point I thought it was the transmission but it shifts smooth and temps are always 150-170. From 0-50 its pretty noticable and from 60 to WOT when I accelerate its alot less noticeable but its there for sure. When I put the truck in park and rev it to 2500 it hear it, when its in neutral i get the same sound. It doesn't squeal when i turn the wheel in park its only a rev thing. I doubt its the power steering pump, no squeal when I turn, resivior full. I cant really get under it until April and im going to change the serpentine belt and check for loose pulley, but what else can it do while im in there? I have low hopes for this because it sound like its coming from the top of the engine and not the front per se. When i open the hood and rev it, it's just a general whine. But since the diesel tech insisted it hpop was going to blow and i have driven it for 30 k miles like this it got me thinking maybe i need to figure it out. How will i know if the alternator is toast. Batteries new have not died at all, 13.1 on the scan tool when running so i cant see it being the alternator. Could it be the water pump ? Also i may drive like an ******* sometimes but i doubt that has anything to do with the noise. I attached 2 videos one from in the cab and one under the hood, any help would be greatly appreciated, I just don't want to get stranded. thanks guys. Lastly the truck starts right up every single time NO hard starts
2004 stock 111k miles.
Old Mar 1, 2024 | 11:58 AM
Jokester00's Avatar
Jokester00
What brought you to this noise? Are you having performance issues?
Sure sounds like the alternator to me...what is your system voltage @ KOEO & while at idle?
-jokester
Old Mar 1, 2024 | 12:03 PM
bismic's Avatar
bismic
13.1 voltage output from alternator wouldn't make me particularly happy.
Old Mar 1, 2024 | 12:23 PM
04-6.0 BinkBink
5th Gear
No performance issues maybe MPG ~12 with 33" tires, but the mechanic insisted my HPOP was going to blow up. KOE off 12.0, with engine on 12.8 to 13.1
Any recommendations on an alternator brand or one to stay away from ?
Old Mar 1, 2024 | 12:24 PM
04-6.0 BinkBink
5th Gear
what should it be at ? and would an alternator or the alternator pulley make that noise ?
Old Mar 1, 2024 | 12:51 PM
bismic's Avatar
bismic
IMO your alternator should at least be 13.8 as a "float charge", and 14.2 minimum for charging.
I would think that a pulley would be a squeak, not a high pitched whine - if that makes any sense.
Old Mar 1, 2024 | 12:57 PM
04-6.0 BinkBink
5th Gear
Exactly my thought but an alternator going bad will make a whining sound? Either way it’s low I’ll replace it with the belt too
what alternator would you recommend?
Old Mar 1, 2024 | 01:03 PM
bismic's Avatar
bismic
Do the belt first. A slipping belt can impact the alternator output.
Old Mar 1, 2024 | 01:13 PM
Jokester00's Avatar
Jokester00
Or...remove the belt and start the truck to see if the whine is still there. This would tell you if the whine is still there or not. If it is gone...the noise is/was related to a belt driven accessory. I wouldn't let it run for too long without the belt though, as your water pump wouldn't be circulating any coolant during that time and your alternator wouldn't be charging your batteries either. But you could do it long enough to see if the noise is gone.
-jokester
Old Mar 1, 2024 | 01:17 PM
FiveOJester's Avatar
FiveOJester
Sounds like an engine accessory. You can take a breaker bar or other long metal object and use it as a stethoscope. Push one end on the alternator near the bearings and listen on the other end. You can very quickly figure out where the noise is coming from.
Hopefully the alternator as that's easy to change!
Regarding your HPOP, I assume your truck is an 04? Do you still have the original? The 03-04 pumps are known to fail but most people don't touch them until they start seeing signs. There are some mfgs' that make upgraded ones that last a long longer than the stock ones.
The ICP and IPR numbers from your video look just fine. I wouldn't worry about it for now unless you want to be preventative.
04-6.0 BinkBink
5th Gear
-jokester
I can rev the engine without the belt too? The noise isn’t particularly present during idle or it maybe be but the typical diesel idle may be louder so it’s not noticeable
Old Mar 8, 2024 | 02:49 PM
Fuzzpuss's Avatar
Fuzzpuss
Yes, just not a lot or for very long as Joker pointed out.
Sounds more like a howl than a whine to me which could be a cavitating water pump or an issue with the exhaust.
If a mechanic ever told me that my HPOP was going to blow-up, I would never go back. Just sayin'.
Old Jul 4, 2025 | 07:07 AM
Jimdog571's Avatar
Jimdog571
1st Gear
Did you ever figure out this noise? Mine is doing the same.
Old Jul 15, 2025 | 12:00 PM
fordtruckrodder's Avatar
fordtruckrodder
Can you explain how you are able to get the engine parameters on your dash unit?
Hartwig
Feb 9, 2023 03:42 PM
Kcman116
6.7L Power Stroke Diesel
Jan 9, 2017 10:40 AM
651_F350_KR
Feb 8, 2014 11:05 PM
wildcat99
2004 - 2008 F150
Jun 8, 2008 12:24 AM
V10man
May 29, 2002 01:05 PM
