Went to back it out of the shed last week end and it wouldn’t go into reverse
Ran it through all the gears a couple times and it finally went into reverse. I backed it out into the driveway It went into forward gears fine. But took several seconds to shift into reverse. Drove it down the road a couple miles to warm it up and it shifted into reverse fine
The next day we drove it 30 miles to get propane and it worked fine
Then we took it camping for a trip
It got down to 30 degrees When we went to leave it wouldn’t engage into drive or reverse
Cycled through the gears and it seemed to engage but it only moved 10 feet and stoped. Shifted through the gears again and it moved a few more feet. Shifted to second gear and it got moving. Shifted back to drive. Drove 40 miles home no issues
Got home let it set over night and the next morning. The same no going into forward or reverse After a few tries it worked great
The next after noon 70 degrees out fired up and shifted great
After searching everywhere on what it’s doing I realized that a couple times after it seemed to be worked shifting into reverse would kill the engine or lug the engine down until I had driven several miles
So it’s all temperature related
Is a valve hanging up in the tcc solenoid when it’s cold?
Pulled the codes tonight and none of them are transmission related
I am thinking it’s a faulty solenoid pack but hate to buy a $200 part if I am missing something
I have a Jeep that was having problems with hard shifting in the mornings. Did the suggested fluid changes and nothing seemed to work. I then came across a post that suggested using Lubegard additive. Ran it for about 3 months and the transmission shifts fine now.
Before doing an OH or replacing anything I would try Lubegard.
