No trailer brakes.
Old Feb 26, 2024 | 12:49 PM
6point0's Avatar
6point0
No trailer brakes.
2005 f 250. They will work if I use the slide on the aftermarket brake controller. They dont activate with the brake pedal. The indicator light will adjust with the gain ****. Apparently there is some sort of cruise control- trailer brake relationship. The cruise hadn't worked since I bought the truck , same as the trailer brakes. I replaced the sensor on the master cylinder and the cruise works but not the brakes. If anyone has any suggestions I'd love to hear them.
Old Feb 26, 2024 | 08:09 PM
seventyseven250's Avatar
seventyseven250
Bad connection to the trailer. Truck isn't "sensing" the trailer, and the manual slide overrides that requirement. Something near the bumper or ball is not right.
Old Feb 27, 2024 | 11:36 AM
justanotherjo's Avatar
justanotherjo
check to see that the wire to the switch on the brake pedal is still properly attached. This triggers the brakes when the brake light turns on with aftermarket controllers.
Old Feb 27, 2024 | 01:45 PM
6point0's Avatar
6point0
For unrelated reasons, I have recently put a new harness ,plug and bracket on it. The problem was there before and after. Unless there is damage to the truck harness somewhere.
the brake switch you say? If it is hooked up what are the chances that the switch is cooked?
Old Feb 28, 2024 | 09:40 AM
justanotherjo
if your brake lights on the truck come on, the switch is good. The aftermarket controllers use this same wire to trigger the brake controller.
Old Feb 28, 2024 | 02:16 PM
6point0's Avatar
6point0
I was wondering that. Yeah, they work and all the lights on the trailer work as well.
what are the chances that the brake controller is toast?
Old Feb 28, 2024 | 02:32 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Is the controller the stock one that came with the truck or is it an aftermarket controller ? If aftermarket, what make/model? If it is the stock controller how do you KNOW the trailer brakes are not working? You do know that they will not work with the brake pedal until you are traveling about 8MPH don't you? They work once you hear the automatic door locks go down.
Old Feb 28, 2024 | 07:21 PM
6point0's Avatar
6point0
I'm thinking it's this one
https://www.partsengine.ca/9030-vp-t...hoCrWcQAvD_BwE
as far as how do I know? The light doesnt react to the brake pedal. Crank the gain and the trailer wheels wont lock up. Hit the side and it will activate at the same settings.
Old Feb 28, 2024 | 07:58 PM
seventyseven250
Wow, I had that one years ago and yeah, you sure could tell when it was functioning. If you do decide to replace it, go with the Tekonsha Prodigy for a few more bucks, miles better.
Old Feb 29, 2024 | 07:19 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
Tekonsha is a very reliable company. I would call/email them to request help. They will do most anything to keep a customer. Go to their web site for help.
Old Feb 29, 2024 | 08:19 PM
6point0's Avatar
6point0
Now that's the info I needed to hear. Thanks for the heads up.
rphghs
Aug 29, 2023 06:08 PM
Beachums
2015 - 2020 F150
29
Aug 29, 2017 10:02 PM
elkarcher1716
2009 - 2014 F150
13
May 15, 2014 09:17 PM
CPT Morris
All Things Towing
Jul 27, 2010 03:43 PM
RussF350
Jun 6, 2010 07:42 PM
