Sponsored by: Real Truck
brake control issues
Old Jun 6, 2010 | 07:09 PM
RussF350's Avatar
RussF350
Hey guys, having some problems with my brake control in my 2010 F350. I do not have the stock brake controller so I had get an aftermarket one. I got the factory harness from ford (brand new truck did not come with one but that is an entire other issue). So I installed the the new brake control and with no trailer attached the digital readout works, I hot the brakes and it climbs from 1.0 - 10.0, I thought this was only suppose to register when the trailer is hooked up. So I hook the horse trailer up and everything works as it should. Hook my construction trailer up to it and as soon as I hit the brakes the trailer brakes lock up and will only unlock when I disconnect trailer from truck. I hooked up to my buddies quad trailer this weekend and it seems to slow it down but no matter how I set the gain on the control it does the same thing. And when I apply constant brake pressure (30% brake or something) the digital readout jumps around 2.0, 3.5, 9.0 5.4 etc, with the same brakes applied. Anyone know what is up here? I am in the market for a new controller, what do you guys use?
Old Jun 6, 2010 | 07:42 PM
Saz221's Avatar
Saz221
Brake controller
IMHO the best aftermarket controller out there is made by Prodigy. They are a little more pricey but well worth the $.
contento
All Things Towing
Jun 7, 2014 07:16 AM
KHAYES
All Things Towing
Jun 12, 2013 12:09 PM
Chalkie
All Things Towing
Aug 26, 2012 09:19 PM
lawnspecialties
Jun 23, 2011 08:07 PM
JE917
Apr 10, 2010 04:43 AM
