1996 Ford F150 ignition problems
Old Feb 17, 2024 | 01:27 PM
68Ranger390's Avatar
68Ranger390
Hello members, This truck is as states above....... and I will say that I am certainly an old school mechanic, and which I am not up on fuel injection motors much. So, my issue is the truck 5.0 liter motor will start up in the morning, and will run till normal operation (warm)
and you shut the motor off, and wait for 15 to 30 seconds, it may start, and it may not. My brother and I have replaced the pickup coil, the main engine coil, and I believe it's called the ignition module, and it is mounted on the inside of the drivers side inner fender. The main coil, and pickup coil inside of distributor was
bought at NAPA. The ignition module was bought at O'Reillys auto parts. I was sure that the first one was bad, so we exchanged it for a new one..... but sometimes it will not start. Beginning to think this one's bad too. I am frustrated with these Chinese built parts! Is there something made in the USA? Maybe from summit racing or else where? Please help! I like driving Ford trucks! Appreciate any and all help! Thank you.
Old Feb 17, 2024 | 02:17 PM
R&RFord's Avatar
R&RFord
I would suggest you confirm you are losing ignition before proceeding further down the rabbit hole.
Old Feb 17, 2024 | 02:26 PM
R&RFord's Avatar
R&RFord
Get Motorcraft/Ford parts.
I use LMR or a Ford dealer. Occasionally Amazon.
I have gotten several bad Motorcraft parts from RA. I still use them for other brands just not Motorcraft.
I will often hunt down NOS Ford/Motorcraft before going aftermarket.
Old Feb 17, 2024 | 03:43 PM
Scndsin's Avatar
Scndsin
" it may start, and it may not. "
Spins/doesn't spin? Spins doesn't catch?
Primes the pump selected at power on each time prior to cranking?
Tested with starting fluid when no-start?
Ever had the computer out?
Occasionally they'll throw a PIP code, but not 100%
Most Mototrcraft stuff, sadly is China now made, but does have to meet Ford standards & QA is pretty consistent & worth buying over something else.
Old Feb 18, 2024 | 04:42 AM
manicmechanic007's Avatar
manicmechanic007
It would take about half a day to explain to you what I would do
But a noid light and 2 inline spark testers and a fuel pressure gauge is a start
A code test is in there right at the start as well
I got a feeling your processor has some bad capacitors (they cause intermittent misfires and no starts when they leak and start failing
I agree to find Motorcraft or Ford parts regardless of price
New Old Stock is what I look for first on Ebay
Old Feb 18, 2024 | 11:11 AM
Soup bean's Avatar
Soup bean
https://www.ford-trucks.com/forums/1...k-93-96-a.html
Norton72
May 23, 2012 09:48 PM
backdraft341
Jun 30, 2010 09:46 AM
VikingBabe
17
Mar 10, 2007 12:41 AM
steeldust
Electrical Systems/Wiring
Jul 11, 2003 08:40 PM
73ford
Mar 9, 2002 08:01 PM
