Amp light
Old Feb 17, 2024 | 10:16 AM
Gjorgjija's Avatar
Gjorgjija
Amp light
Hi
New day new problem 🥴
As you already know from my previous threads, I have problem with air intrusion (next week I will replace return lines), as well as problem with vacuum in fuel filter ('fuel filter' light lite, when I press schrader valve, engine goes off), today I crank the engine and of course need too much time to get white smoke and finally engine was running.
I drove it for about 10-15 minutes and power off the engine.
Crank it again, start imideatly... Few times like that, and was ok.
I rest for about 1hour, twist the key at ON position and 'Amp' light comes on the dash.
What is happening now, any idea?
Also try to start the engine, cranking but without success.
I have new batteries with enough CCA.
Old Feb 17, 2024 | 11:02 AM
Prototypemech's Avatar
Prototypemech
The amp light always comes on with the key-on engine-off. It means your alternator isn't charging the battery, which is correct if the engine is off.
It has nothing to do with your no-start condition.
Old Feb 17, 2024 | 11:58 AM
Gjorgjija's Avatar
Gjorgjija
Thanks.
I am hoping that will resolve my previous problem (fuel filter light, vacuum in the filter).
I really like the van...
Old Feb 17, 2024 | 12:08 PM
Prototypemech
Replace your engine driving fuel pump. Buy a Motorcraft/ford/international brand.
Old Feb 17, 2024 | 12:22 PM
Gjorgjija's Avatar
Gjorgjija
that will be next phase, if needed. first to replace return line, and then will check fuel pressure. If needed i will replace LP.
I am doing everything alone, and I don't have any knowledge about this vehicle, I am not mechanic. replacing LP will be chalenge
zorro101
Nov 11, 2021 10:21 AM
danielboone4
May 5, 2021 06:55 PM
Capt.Schenk
27
Oct 15, 2014 11:56 AM
triton_2002
Dec 29, 2003 08:14 PM
PGD_ranger
Jan 2, 2003 06:43 AM
