Sponsored by: Innova
Protection Light On
Old Dec 10, 2003 | 03:41 PM
triton_2002's Avatar
triton_2002
Protection Light On
Does anyone have any suggestions as how to diagnose an amp that has the "protection" light on? I've checked all the obvious things: crossed wires, loose connections, overheating. The amp will come on and then the protection light comes on right away and there is no sound. It happened all of a sudden, it had been fine since installed about 1 yr. ago. I guess I have a dead amp, but hoping someone has an easy fix
Old Dec 10, 2003 | 03:53 PM
drunkenmonk's Avatar
drunkenmonk
usually in cases like that I usually eliminate any possible external problems(blown speakers, shorts, opens, etc.) the look inside the amp. often a component burns up inside and you can see telltale signs like burn marks on the board. if I find a burned component, usually you can resolder a new one in, and that fixes it. beyond this, diagnostics are more complicated than we could really get into here, and require test equipment, so I'll leave it at that, since I am just a hobbyist, and not qualified to teach a class in electronics.
Old Dec 10, 2003 | 05:34 PM
mtech2's Avatar
mtech2
Disconnect everything from the amp except the positive and negative battery terminals. If the light still comes on check the leads for proper voltage both while the engine is running and while the engine is off. If the proper voltage (11.8-14.4V) is present you have blown your amp. At this point check your owners manual to locate any user serviceable parts (ie fuses)
Old Dec 11, 2003 | 01:28 AM
Robert Red Ford's Avatar
Robert Red Ford
what kind of amp is it?
Old Dec 29, 2003 | 08:14 PM
triton_2002
thanks for all the suggestions. Finally had a chance to mess with it and found the problem -- blown speaker. I guess the old MTX's finally gave out, so now I need to shop around for a couple of subs.
JimsRebel
'80-'86 HOWTO's
18
Jan 23, 2025 04:19 PM
exbxtoy
31
Dec 16, 2016 10:09 AM
jvmcc
Electrical Systems/Wiring
Jul 21, 2016 05:48 PM
Jonesy0027
2009 - 2014 F150
May 16, 2014 10:55 PM
Captain Mike
Nov 18, 2002 12:18 AM
