Amp warning light on
Old Nov 11, 2021 | 07:41 AM
zorro101's Avatar
zorro101
Trailering
1993 F150 inline six.
My red amp warning light came on this morning. Battery turns the motor over strong and it starts right up. Runs normally no noticeable problems, but the light remains on.
Is this just battery getting weak or something more problematic? Don't want to get stranded on the highway.
Thanks,
Old Nov 11, 2021 | 07:58 AM
Conanski's Avatar
Conanski
With a multimeter measure the battery voltage when the engine is off and compare it with the voltage measured with the engine running. The engine running voltage should be higher at around 13,5v, if it is the same or lower than the engine off reading the alternator isn't charging and should be replaced.
Old Nov 11, 2021 | 08:16 AM
Edgethis's Avatar
Edgethis
Could be overcharging also. The voltage regulator is the part on the alternator that usually fails first. Just went through this in my truck. Took 3 different reman alternators to find one that actually worked too. Definitely test it at the store if you can.
Old Nov 11, 2021 | 08:41 AM
zorro101's Avatar
zorro101
Trailering
Will do, thanks for quick reply.
I can hardly see the red light in the daytime. First noticed it this morning before daylight. I am wondering if it has been on for a while but not noticed.
Old Nov 11, 2021 | 10:21 AM
zorro101's Avatar
zorro101
Trailering
Update.
Checked all the connections to the alternator and found a loose wire. Reconnected it and the light went out.
Everything works good.
Thanks for the feedback
Bob Gervais
Mar 8, 2010 05:40 AM
sumbuddyloanmea.10
Electrical Systems/Wiring
Jul 29, 2009 06:32 PM
triton_2002
Dec 29, 2003 08:14 PM
downdeephuskyjerk
Nov 9, 2003 07:02 PM
shand32783
Aerostar
Sep 18, 2003 03:57 PM
