how do I know when to shift?
Old Feb 14, 2024 | 01:50 PM
Lame_Si's Avatar
Lame_Si
1st Gear
Hi new here and new to ford trucks, The last few years I have been real into Honda civics, particularly manuals. During my owner ship of hondas I have been spoiled with the convenience of a tachometer. Recently I have been searching for 93-96 5.0 F150 manuals for the nostalgia factor of my grandpa. But during my search I noticed alot of manual F150s dont have tachometers, so to wrap up this question, how do I know when to shift my manual 5.0 F150? Not trying to hot rod or nothing, just trying to not over rev and damage the motor of a Truck Ive worked so hard for. Much appreciation
Old Feb 14, 2024 | 02:47 PM
jas88's Avatar
jas88
Ideally you should shift at the RPM of highest torque value, or torque peak. For your engine that is at 2400 RPM. You're gonna have to guess without a tach, but 2400 is pretty low so it's not going to be screaming.
Old Feb 14, 2024 | 03:17 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The computer won't allow you to overrev the engine. It will shut off the injectors before you get to an RPM that could cause damage.
You don't need a tach to know when to shift. As you accelerate in first gear, at some point the acceleration will be reduced. This is when it is time to shift to second gear. The same thing happens in every gear, that's the time to upshift to the next gear.
Old Feb 14, 2024 | 05:41 PM
Mudsport96's Avatar
Mudsport96
You just have to feel the truck. You will know when to shift by how the acceleration feels.
Old Feb 14, 2024 | 07:31 PM
Conanski's Avatar
Conanski
FYI.. A dash cluster with a tach from the same year F series or Bronco (and others close in age) is a plug and play swap. What year is your truck?
Depending what vintage truck you have the 5.0 made peak HP at 3000-4000rpm so there is no point spooling it up beyond that. The early motors(93 and older) in particular sound like they are screaming at that rpm so a tach would really help you get used to what it sounds like.
Old Feb 14, 2024 | 07:56 PM
OBSession05's Avatar
OBSession05
Mudsport96 makes a very good point. Every truck is going to feel slightly different so just get a feel for it and you should be able to hear and feel when it wants to shift. I've only drove 70's and 80's trucks with 4 speeds in them but those usually liked to shift at around 2,200 rpms.
Here's a video that might help. Listen to the tone of the engine as he shifts.
Old Feb 14, 2024 | 08:07 PM
85e150's Avatar
85e150
This will help also. The listen to the engine--you'll get it.
Old Feb 14, 2024 | 08:09 PM
85e150's Avatar
85e150
Once you get used to it and are more familiar with the rpm/speed/load in each gear, you can skip gears if you like. You are not required to shift through all the gears.
1-2-4 or 1-2-5 works just fine in no load, easy going.
Swerving suggestion.
Old Feb 14, 2024 | 08:28 PM
Soup bean's Avatar
Soup bean
Yes to listening to the engine.
Turn off the stereo and roll down the window every chance you get.
First and reverse gears in the M5ODR2 is geared very high. It's awkward in parking lots, trying to get into parking spaces.
Old Feb 14, 2024 | 09:01 PM
AuroraGirl's Avatar
AuroraGirl
only in sequential transmissions
Which you are not going to find in a truck like this unless you put one in, for some reason! lol
Old Feb 14, 2024 | 09:13 PM
BobcatNT's Avatar
BobcatNT
Your dad fusses at you when you overwind the truck when you learned to drive .
Old Feb 14, 2024 | 09:36 PM
85e150's Avatar
85e150
Who mentioned sequential transmissions? Yes, you have to go through all the gears in those but that's not an issue here.
Old Feb 14, 2024 | 09:47 PM
Conanski's Avatar
Conanski
Not so much when there are 4.10 gears in the axles, but yes reverse has a rediculously high gear ratio... backing a heavy trailer up an incline is almost impossible in some cases.
Old Feb 14, 2024 | 10:17 PM
OBSession05
You can skip gears on these manuals. It's only sequential you can't skip. With my t18 I've started in 3rd and it was fine.
Old Feb 15, 2024 | 06:20 AM
tjc transport's Avatar
tjc transport
i ain't rite
you can skip gears in any trans............if you know how to shift.
when empty on flat ground i only use 4 or 5 gears in my 18 speed. even when loaded i usually only use 8 or 9.
the only time you need all gears is pulling a very heavy load.
Dean2012
2009 - 2014 F150
Aug 11, 2017 09:20 AM
EaTmYtAiLpIpEs
Dec 14, 2008 07:40 AM
z 97ford1
1997 - 2003 F150
Nov 3, 2006 06:53 AM
DAJF150
Sep 26, 2005 12:04 PM
jettfuel
Jan 23, 2003 02:27 PM
