Converting to power steering
Old Feb 12, 2024 | 07:26 PM
Omni43's Avatar
Omni43
How hard is it to covert to power steering? I've got a 1972 F250 2WD.
Thanks.
Old Feb 13, 2024 | 10:30 AM
Jim_K's Avatar
Jim_K
Depends on how much time, money, and effort you want to put into it, but in my opinion, I wouldn't do it without a donor/parts truck, as that way you'll have everything needed (bolts, brackets, pump, steering gear, etc). The pump may not work, the hoses may leak, and the gear may be loose/worn-out, but at least you'll have something to start with.
Piecing something together? Not for me. Life's too short.
Good luck!
Old Feb 13, 2024 | 11:14 AM
Green72F250's Avatar
Green72F250
Here is some information on how to do the conversion:
How to Install Power Steering in a 2WD F100/250/350 - FORDification.com
Old Feb 14, 2024 | 02:06 PM
tcanthonyii's Avatar
tcanthonyii
I have a column and steering box from a 72 f250 I'd part with as well as the ps bracket. Unfortunately the pump and hoses were gone when I pulled them. The gear box as 60k on it (was a camper). I'm swapping the 72 column into my 71 as it's tight and my 71 is little worn. it would be a great start to the conversion.
Old Feb 14, 2024 | 02:18 PM
GrandStang's Avatar
GrandStang
If you can find a donor, I'd recommend going that route. I pieced things together and ended up paying WAY more than I should've. I got burnt and was sold the wrong pump, bracket, and column. It's on me, I should've done more research, but the sounded like he knew what he was talking about, so I trusted him. My mistake.
In the end, I was able to get steering box, had my original column shortened, went with a more modern pump and a bracket off of Amazon, and new hoses all around. I've a 302 though, so parts were somewhat easier to find, but still had to cough up the money for it.
I regret going down the path I went, but don't regret the outcome. I live in Los Angeles and my rig has 31x10.5s, so power steering is practically a must.
Old Feb 14, 2024 | 02:41 PM
Omni43's Avatar
Omni43
I hear you; these things can be a bear to drive sometimes.
Old Feb 15, 2024 | 01:15 PM
Jim_K's Avatar
Jim_K
Of course you could always go with an electric power steering kit like this:
https://www.flamingriver.com/fr40200...power-steering
There's a company that makes them for trucks as well, but I can't find them at the moment.
Old Feb 17, 2024 | 09:52 PM
1browski's Avatar
1browski
I did put an EPAS system in my truck but it is 4wd. It is a lot easier on the 4x4s.
DerekP
Aug 1, 2021 03:20 PM
hillcountryflt
59
Mar 26, 2016 03:34 PM
dwrestle
Jul 29, 2007 09:01 PM
lilpro
Aug 14, 2006 05:42 PM
