Instrument Panel Voltage Regulator
Old Mar 11, 2024 | 05:23 AM
  #46
manicmechanic007's Avatar
manicmechanic007
Yes, that method is for radical cams but works for them all
There are a few ways to do it and they are all correct
The problem with big cams is the clearance ramps
Old Mar 11, 2024 | 10:19 AM
  #47
Mjac167's Avatar
Mjac167
Yes, but as another guy pointed out to me after I pinned my hopes on a valve adjustment, almost all 302s have pedestal mount rockers and are not adjustable, everything is pointing to an internal vacuum leak. I have a Cometic High Temperature Steel (HTS) Intake Manifold Gasket coming, if it ever gets here USPS is doing what USPS does, and we will try that. That valve adjustment technique is good to know though, it helps you understand how a valve train works, especially with a cam. It was helpful.
Thanks
mjac
BGF100
Dec 18, 2015 01:45 AM
wavetrain75
Dec 17, 2012 08:57 PM
beetle
Electrical Systems/Wiring
Jun 26, 2007 03:07 AM
JBronco
1978 - 1996 Big Bronco
Feb 10, 2005 03:38 PM
bronco2ok
1983 - 2012 Ranger & B-Series
Feb 20, 2004 03:46 PM
