Instrument Panel Voltage Regulator
Thanks
mjac
Pull the PCV valve from the valve cover and see how much vacuum is on the other cover with it removed versus putting it back in there
I am trying to visualize your what? 72 Econoline? what engine?
I am a little loss, pull the PVC Valve then check the vacuum at the filler cap on the other valve cover?…And what exactly will this show?
I did check the vacuum at the PCV Valve and it was the same low 10-12 lbs. I did read somewhere about pulling one of the plugs in the manifold and check the vacuum there, I do not know what this is supposed to show though.
Thanks
mjac
On an engine that is working properly, you leave the PCV in there and pull the vent on the other valve cover
Place a small piece of paper over the vent hole and the PCV valve should have enough vacuum in there to suck the piece of paper down to contact the grommet
You pull that small piece of paper away and the vacuum in the crankcase wants to suck the paper back down to the grommet
That is normal
With an intake leak into the valley (crankcase) the vacuum will be less or gone at idle and may increase with engine speed
That problem used to be common on 2.9l engines in Rangers and Bronco IIs
Sucked part of the intake gasket out in the valley
Pretty hard to diagnose really
A smoke test will shoot smoke out the valve cover breather
When I did the smoke test with a rigged up smoke machine using a little dc tire inflator and a smoke pot, I taped over the breather hole and put the smoke through the PCV Valve Grommet. Wasn’t sure it was working being rigged up and all but smoke was pouring out of the dipstick, so I guess it was.
The plan is to do a static compression test, a running compression test would not give me much more information except what valve in the cylinder was acting up, and then adjust the valves using a technique I read about. The way this guy did it, he would take one cylinder at a time, bump the engine until the exhaust valve was all the way open which meant the intake valve was closed, adjust the intake valve by torquing down until there is not up and down movement of the push rod and give it (I believe) another 3/4 turn. Then do the exhaust valve in reverse. I am not sure how I will tell the exhaust valve or intake valve is all the way open but I guess it may be apparent, I don’t know. He said this improved performance even in an engine that had been “tuned.” One guy said his engine was running very poorly and two cylinders had no compression (I think he said he had low vacuum too) and after he adjusted the valves all of the problems disappeared.
Edit: Got the Alternator today, going to put it in and see if the draw disappears and it was a diode like y’all said.
Thanks
mjac
There is no real good failproof way to test for that IMO
That is why I referenced the PCV test to check for subtle differences in idle quality and vacuum numbers while observing the piece of paper
I agree with checking the valves, a fluctuating gauge you do not have you said right?
What is the ignition timing set at?
it would seem you figure it is an internal vacuum leak by process of elimination. You eliminate everything else and that is the only thing left, then you are pulling manifolds.
The vacuum gauge when hooked up in various places, is a steady low vacuum reading about 10-12, it is not pulsating or wildly bouncing. From what I understand a wildly bouncing vacuum reading means a stuck valve or a valve that is not seating and a steady low reading means a vacuum leak. Do you approve of that valve adjustment technique and is it difficult to determine when the exhaust or intake valve is fully open when looking at them?
The ignition timing set with the DUI Performance Distributor is backyard, advance to the highest vacuum reading. ( When the vacuum numbers were correct) I don’t know the exact degree, that is something I have been meaning to do with the timing light I bought.
Thanks
mjac
Set it with a light to a number, then you can adjust up or down if it pings or lacks power
I used to run my Z-28 at 20 degrees here at 5000 feet
You can adjust the timing to the highest vacuum the motor will achieve and then back it off a bit
That will be close but still not a number
You need a few numbers to verify timing is correct and at the right time
Like checking it with the vacuum advance off and testing how much and when the mechanical advance kicks it
You can also play with spark port versus manifold vacuum for the vacuum advance supply
You might be able to get it to run decent at your altitude and fuel quality
Those Densos will leave some fuel behind on a Ford
I have done a ton or emissions testing over the years
Denso in a Nissan, Honda or Toyota, Motorcraft in your Ford
mjac
If you can see lightning, the plug wires need to be replaced and the cap and rotor checked
Those fancy valve adjustment techniques do work and I use that procedure on my Boss 302 with a radical camshaft
Adjust the intake when the exhaust starts to open
Adjust the exhaust when the intake starts to close
Thet call that the EO-IC method and is about the only way to get one correct with a radical cam profile
You can just torque yours down to the spec as they are positive stop rockers (no adjustment) (unless you swapped heads or the motor with earlier)?
