Instrument Panel Voltage Regulator
Old Feb 16, 2024 | 07:27 AM
  #31
Mjac167's Avatar
Mjac167
I think I understand it, you are waiting just a tick longer than the other guy who is adjusting when one valve is completely open, you are just waiting for it to just start its other movement. Do I have this?
As far as I understand, either your adjustment bolts have shoulders or they do not. Shoulders, you just torque them down. No shoulders, torque down until there is no up and down movement of the rod then go another 3/4 turn. I don’t believe mine have shoulders. The engine was changed but the guy did not put the engine in he said he did so I do not know. He said he put in a Jasper and it is not a Jasper.
Thanks
mjac
Old Feb 16, 2024 | 08:53 AM
  #32
Mike1's Avatar
Mike1
Maybe, never really tested one using a DVOM or an analog multimeter
Just a test light looking for a pulsating dim glow
That is how you test the gauge circuit
First with a test light to check for the pulsating dim glow
Then, if present you ground the wire and watch the gauge peg
It either pegs or it don't
It either needs a sender or it needs the wiring ohmed out to the gauge and the pulsating voltage checked there
LOL I knew there was a reason I kept hanging onto my old test lights....LOL
Old Feb 16, 2024 | 09:20 AM
  #33
Mjac167's Avatar
Mjac167
But my Fluke 115 costs $266.
Old Feb 16, 2024 | 09:37 AM
  #34
Mike1's Avatar
Mike1
I've got a fluke, don't remember the model now. Back in 1995?? Cost me about $300, used it almost everyday for about 10 years, now It checks battery voltage a couple times a year and maybe gets switched over to continuity every now and then. They are nice to have but you could have done the same thing spending $10 on a meter from harbor freight. Enjoy your meter while you can because if you have a kid at home, it'll soon wind up missing,, blown up or found out in the middle of the driveway....Just personal experience here...LOL
Old Feb 16, 2024 | 09:43 AM
  #35
Mjac167's Avatar
Mjac167
$300 blown up, missing or out in the driveway?
mjac
Old Feb 16, 2024 | 11:07 AM
  #36
Mike1's Avatar
Mike1
Well, lets just say I watched a guy plug into his 20amp side on his meter, then for what ever reason decided to check a 480V circuit coming into the factory...Boom, Flash smoke and a trip to the hospital for a minor case of retina burn.
Missing or in the driveway....I found both...Son took my meter to work on his truck, I needed it about a week later and couldn't find it, so as with many of my tools, I go directly to his truck, look in the floorboard where I find a couple of my box end wrenches and a half dozen sockets a ratchet and a couple of extensions, all of which I took back, but no meter and for some reason, I popped his hood and there it is laying on top of the wheel well. I'm surprised it didn't bounce out. Then about 2 weeks after that I came home to literally finding it laying in the middle of the driveway. He said he was checking wiring and when he "Cleaned Up" it must have gotten knocked under the truck so he didn't see it when he took it out for a test drive. I have told him he better take care of the tools, because they become his when I'm gone, so he treats them like garbage, when I die, he gets garbage. All my Snap-on and Matco tools are just about gone, I started buying Craftsman, but he takes those too, so I'm am now officially an HF guy. I'm too old to spend big buck on expensive tools. If I use it and it works great for me. If he uses it and it breaks, too bad so sad, go buy a tool. I tried to tech him tool etiquette, and to clean them and put them away, especially when they don't belong to him, but it just never sank in and all the yelling and cussing in the world doesn't do any good.
Old Feb 16, 2024 | 11:18 AM
  #37
Mjac167's Avatar
Mjac167
Maybe one day.
mjac.
Old Feb 16, 2024 | 06:08 PM
  #38
Mjac167's Avatar
Mjac167
How good of an engine is the Boss 302, from what I understand, it dominated Can-Am Racing in the 70s.
Thanks
mjac
Old Feb 17, 2024 | 02:35 PM
  #39
Mjac167's Avatar
Mjac167
You want a solution to your problem?
mjac
Old Feb 17, 2024 | 03:36 PM
  #40
Mike1's Avatar
Mike1
😂😂😂 which problem? I have several. My solution would be to buy 100 acres move to the middle of it and be left alone....lolol
Old Feb 17, 2024 | 03:48 PM
  #41
Mjac167's Avatar
Mjac167
You are on the right track, “ be left alone.”… We are talking about the immediate problem you expressed so frustratingly in your post of your tool supply being depleted by various means, that I conveniently quoted for your easy reference.
mjac
Old Feb 17, 2024 | 06:35 PM
  #42
Mike1's Avatar
Mike1
mjac
What would your solution be? Im all ears.
Old Feb 17, 2024 | 11:13 PM
  #43
Mjac167's Avatar
Mjac167
IPad/WiFi crashed, just got it going
Well, here goes. You answered your own question, “ My solution would be to buy 100 acres, move to the middle of it and be left alone.” If that is not feasible, “buying 100 acres” becomes the metaphor and you have to create the “100 acres,” the haven, where you will be left alone. Build yourself a shop, if you already have a shop, renovate it, to represent a fresh start. Be sure to include a no entry, high security door and very stout security bars and guess who has the only key. Once this is done, you start equipping the shop with tools and equipment with great deals you come across, with one policy in mind, these are one way tools and equipment, they go in and they do not come out, nothing leaves the shop. That is your haven, that is your “100 acres.” Once you are done, start the projects you want to do. In other words, Mike1 is going to do something for Mike1.
I will come up there and build it.
mjac
Old Feb 21, 2024 | 10:09 AM
  #44
Mjac167's Avatar
Mjac167
Those old original Duraspark systems sure would throw lightning (I run a Duraspark on my 69 Boss 302) (40kv. is enough)
If you can see lightning, the plug wires need to be replaced and the cap and rotor checked
Those fancy valve adjustment techniques do work and I use that procedure on my Boss 302 with a radical camshaft
Adjust the intake when the exhaust starts to open
Adjust the exhaust when the intake starts to close
Thet call that the EO-IC method and is about the only way to get one correct with a radical cam profile
You can just torque yours down to the spec as they are positive stop rockers (no adjustment) (unless you swapped heads or the motor with earlier)?
I am ready to adjust the valves and see if the problems go away. Your adjustment technique differs from what I read about. This guy was saying you adjust the valves when the are all the way closed and you do that by watching the other valve completely open. You are saying adjust the intake when the exhaust starts to open (a little past being all the way closed) and adjust the exhaust when the intake just starts to close which would be way before it is completely closed. Is your procedure just for radical cams or is it also for mild cams? I have a stage 1 Melling Cam, very mild.
Thanks
mjac
Old Mar 10, 2024 | 07:15 PM
  #45
Mjac167's Avatar
Mjac167
No circuit board, no problem, there it is. The dangling red line would be the 12 volt feed into the voltage regular, the black line coming out of the regulator would be the regulated voltage which feeds the gauges.
