DC-DC Charger
Old Jan 29, 2024 | 08:56 PM
wltrmtty's Avatar
wltrmtty
Trailering
Originally Posted by 67_4_ME
My truck had the 410 amp dual alternator and battery option. My 2024 is getting a 250 amp single alternator.
Yes, that’s what I have, a 250 amp.
Old Jan 29, 2024 | 10:29 PM
kry226's Avatar
kry226
Yes, you should get a DC-DC charger. I just installed one on my TT to charge my lithium batteries while driving, using the OEM 7-wire umbilical. My Victron 12-12/18 is seeing 13-14 volts from the truck on the regular. But since LiFePo batteries have a specific charging profile, it's important that you're able to charge your batteries in accordance with that profile. As long as my Victron is seeing 8v at the umbilical, it boosts to the voltage I select. Since I'm getting 13-14v at the umbilical, it's a breeze for the Victron to provide the 14.4-14.6v that my batteries need to see.
I do have the dual batteries/410 alternator setup, but i have installed NO extra wires coming off the truck batteries. Everything is OEM. But as always, YMMV.
Old Jan 30, 2024 | 07:03 AM
B-ManFX4's Avatar
B-ManFX4
IF he gets the 18 amps that 12-12/18 can output and the 540 AHs of batteries he has are at 20% capacity it will take 24 hours of driving to re-charge them. Using the 12-12/50 unit will allow the batteries to fully recharge in a little over 8 hours - if his alternator survives. Alternators are not rated to output their max amp rating 24/7 but that is a discussion for another thread.
OP - if you are going to bother running cable at all, run all copper 2 AWG welding cable. With low voltage DC, resistance is the enemy and 2 AWG isn't crazy expensive. You also need to run 2 AWG on the RV side. Use a TrailerVision Anderson plug mount at the rear and it will be a sturdy, reliable connection.
I ran some quick calcs for you. The voltage drop V in volts (V) is equal to the wire current I in amps (A) times 2 times one way wire length L in feet (feet) times the wire resistance per 1000 feet R in ohms (Ω/kfeet) divided by 1000: = Iwire (A) × (2 × L(feet) × Rwire(Ω/kfeet) / 1000(feet/kfeet))
For 30 feet of 2 AWG copper cable, at 14.4 volts with 51 amps flowing (assuming you get the full 98.5% efficiency claimed by Victron) you will have a 3.3% loss, about .48 volts of drop.
Old Jan 30, 2024 | 07:09 AM
01tundra's Avatar
01tundra
If you're going to get the 50A Orion I'd definitely recommend wire no smaller than 2 AWG.
By the time you consider the circuit length in the truck (around 25') and the additional to get from the truck to the charger, that's a pretty long circuit.
I ran 4 AWG for our 12/12-30 and that's the smallest I'd go for a 30A charger.
Old Jan 30, 2024 | 11:00 AM
kry226's Avatar
kry226
Originally Posted by B-ManFX4
IF he gets the 18 amps that 12-12/18 can output and the 540 AHs of batteries he has is at 20% capacity it will take 24 hours of driving to re-charge them. Using the 12-12/50 unit will allow the batteries to fully recharge in a little over 8 hours - if his alternator survives. Alternators are not rated to output their max amp rating 24/7 but that is a discussion for another thread.
But that also assumes the alternator is the only charging mechanism and that the trips starts out with batteries at 0%. Plus with the OP's 800W of solar, that situation will likely never exist. Been camping for over 20 years and I've never seen that situation. We don't boondock much as I like my A/C, but if I did, I dang sure would have a solar set-up to keep the batteries going while camping.
It's an easy day for the Victron to top off the OP's batteries while traveling, which is likely all he'll ever need.
Old Jan 30, 2024 | 11:09 AM
wltrmtty's Avatar
wltrmtty
Trailering
I’m currently camping in sw Arizona. By morning, the batteries are at 85% and then back to 100% by 2pm. My main concern is driving during cloudy days when the solar is at low efficiency. Last fall, I camped in the rain for a day and then had to hit the road early, again in dense clouds and rain - I only had one 270ahr battery then. By the time I got to my campsite, I didn’t have enough juice left for the trailer jack to lift the hitch off the truck. I had to go to Northern Tools and buy a hi lift jack to do it. I don’t want that to happen again.
Old Jan 30, 2024 | 11:10 AM
ytechie's Avatar
ytechie
I also think of the DC-DC charger as handy to have in a pinch.
Let's say you show up to storage and your batteries are dead an the landing gear doesn't work. Connect the DC cable, flip the switch to high idle, and you'll be back in business in a few minutes. (I've been in this situation, and used the 7-pin connector, but it's much slower obviously).
Or, let's say you're boondocking and haven't been able to get enough out of the solar. Better to have a generator, but a few hours of high idle on the truck isn't going to cause any harm.
Old Jan 30, 2024 | 11:29 AM
kry226's Avatar
kry226
Absolutely, which is why I'm advocating you get a DC-DC charger. I was prepared to go off of the truck battery as has been mentioned in this thread, but was pleasantly surprised to be getting 13-14 volts at the truck bumper.
Old Jan 30, 2024 | 02:25 PM
HRTKD's Avatar
HRTKD
Thank you to @Avoozl for the link to the new Orion XS charger. That is going to be a hugely popular charger. I run a Victron system and their products are top tier.
However (you knew that was coming, right?) the largest cable the Orion XS can accept is 4awg. That specification is in the "Other" section of the datasheet linked below. There are ways around that like running 0awg (or whatever) to a bus bar right next to the charger, then 4awg to the charger. That would not be my choice. I would prefer to throttle back the output amps to match the wire size on the input side. Keep in mind that 50 amps of output requires more than 50 amps on the input side. So the input wire size needs to take that into account.
https://www.victronenergy.com/upload...charger-EN.pdf
Old Jan 30, 2024 | 02:41 PM
01tundra's Avatar
01tundra
I'd use power posts instead of intentionally undersizing the wire. If you're going to do that, why not just go with a 12/12-30?
I ran the 4 AWG back close to my 12/12-30 and then used 6 AWG from the power posts to the charger.
Amazon Amazon
Amazon Amazon
Old Jan 30, 2024 | 04:43 PM
wltrmtty's Avatar
wltrmtty
Trailering
GREAT conversation. Thank you!!
Old Jan 30, 2024 | 04:55 PM
HRTKD's Avatar
HRTKD
Oh, and don't forget the over current protection. Both sides. Fuses protect the wires, not the device. Well, they do protect the device, but their main purpose is to keep the wire from burning up. A 50 amp load would call for a 62.5 amp fuse or breaker. Round up the next available breaker size.
One fuse on the truck battery/alternator end of the input wire. The second fuse on the DC-DC charger end of the output wire. The general rule is 1.25 times the expected load. The fudge factor is there to avoid nuisance trips. Don't go cheap on the fuses/breakers.
Old Jan 30, 2024 | 07:04 PM
  #28
svtride's Avatar
svtride
Exactly as I did… also enabled charger via tapping into running light circuit that enables rear camera.
Old Jan 31, 2024 | 06:11 AM
  #29
B-ManFX4's Avatar
B-ManFX4
Ummm, I said 20% - you're the one who assumed 0% in your statement. Also, the OP said that exact scenario happened to him so not sure why you would say it will likely never happen? The fact that it happened to him is why he posted in the first place.
If he is running the cable from the battery to the rear of the truck and terminating it in an Anderson connector there is no reason to run smaller cable. He can come out of the Anderson connector on the trailer side and run 2 AWG all the way to the DC-DC charger, then use two of these to make the final connections: Copper 2 AWG to 4AWG Reducing Crimp Splice
Put 2 layers of heat shrink over the entire splice, make sure it is mechanically supported and call it a day. As far as the amperage required, if the Victron is 98.5% efficient as claimed then it will draw roughly 51 amps from the truck. 2 AWG will deliver the amperage with minimum voltage drop, which should keep the Victron unit happy.
Old Jan 31, 2024 | 07:02 AM
  #30
01tundra's Avatar
01tundra
I've been using the engine detect option to trigger ours, it's worked flawlessly with my past 2500HD and Titan XD and also with my current 350.
