Sponsored by: Auxito
Anti theft system
Old Jan 25, 2024 | 05:29 PM
fathervader56's Avatar
fathervader56
1st Gear
Anti theft system
My 2001 f150 was recently broken into and the anti theft system kept them from taking the truck. Unfortunately, they really messed it up and it doesn't start. The anti theft system is discontinued and I had to get a 2002 f150 steering column which the anti theft is different. I just need the wiring in order to get it up and running. This is what I have so far. The wiring is wrong here
Old Jan 26, 2024 | 05:10 AM
manicmechanic007's Avatar
manicmechanic007
Had to get? a 2002 column
Get a 2001 steering column at the junkyard and the wiring will be correct
A Spock mind meld for the wiring may take years to get figured out
Old Jan 26, 2024 | 11:40 AM
BareBonesXL's Avatar
BareBonesXL
Wait, maybe I was right. Power, ground, antenna wires. Find power and ground and the remaining two probably don't really matter which is which. They just transmit the frequency, no polarity.
Use your meter to find power and ground. Edit - it's not as simple as I write it to be, but you can probably figure things out with a meter.
Edit 2 - I don't think the link I had here had the correct image in it.
Old Jan 26, 2024 | 12:37 PM
BareBonesXL
Here's 2003. Probably the same as 2002. Apparently they changed something after 2001. Still just four wires.
Old Jan 26, 2024 | 12:41 PM
BareBonesXL
If the original transceiver is not damaged you could remove it, plug it in, and fasten a spare key close to it. You could probably even place it by the ignition switch and it would work. Ugly but should be effective.
Old Jan 27, 2024 | 07:35 AM
projectSHO89's Avatar
projectSHO89
What, SPECIFICALLY, was damaged/broken? The transceiver? The "system" had a number of parts in it.
FWIW, the colors of the wires to the transceiver are the same for 2000-2003, per schematics. Only thing that changed on the drawings was the reference number of the connector from C297 to C252. Have no idea whether the actual electronics in the transceiver changed.
Tyler Yost
All Things Towing
Jun 9, 2022 05:50 PM
CLDG25
2021+ F150
May 9, 2022 05:28 PM
CLDG25
Mar 20, 2022 09:54 AM
Isa
2015 - 2020 F150
Sep 27, 2021 09:24 AM
JB5587
Jun 13, 2017 02:21 PM
