351 to 460 convert
Old Jan 24, 2024 | 05:41 PM
87f250cag's Avatar
87f250cag
2nd Gear
351 to 460 convert
Hello everyone,
I have a 1987 F250 4x4 that is undergoing restoration. It came factory with a 351w (carb) 4v. and the automatic C6 trans. Upon engine teardown we discovered the block was bad (mulitple cracks when the rod came apart). Since I need to source a new block and a new transmission (metal in fluid), I was wanting to convert it over to a 460 motor.
My question is, will the 460 motor mounts bolt to the frame rails without mods? Also will the 460 C6 trans bolt up to the factory crossmembers without mods? Basically I'm trying to figure out what all else I will need other than the different trans?
Thanks in advance!
-Chris
Old Jan 25, 2024 | 08:02 AM
jas88's Avatar
jas88
You will need to put the 460 motor mount perches on your frame. The trans will bolt to the crossmember OK. Does the 460 have an oil cooler mounted to the block where the oil filter goes? Did your 351W?
Old Jan 25, 2024 | 08:56 AM
87f250cag's Avatar
87f250cag
2nd Gear
Thanks. I haven’t sourced the 460 block yet, I wanted to investigate if it would work first. No my 351 did not have an oil cooler. Looks like a 460 it is.
Old Jan 25, 2024 | 01:34 PM
jas88's Avatar
jas88
The later 460s had a water-to-oil cooler which was mounted on the side of the block where the oil filter goes. The frame crossmember under the motor was chamfered to make room. You may have to run an external oil filter (like I am) if your frame is not already chamfered. You could also cut out the hole in the frame where the oil filter resides on your 351W, making it big enuf to fit the oil filter directly to the 460 block.
Pat54632
Projects
Nov 5, 2016 08:31 AM
fordBigBlock
Engine Swaps
Dec 15, 2011 07:09 PM
pianoguy
Jun 11, 2010 01:23 PM
flyguy1
Sep 10, 2001 01:02 AM
67f250
Offroad & 4x4
Jan 25, 2001 05:46 PM
