A/T column shifter
Old Jan 23, 2024 | 06:49 PM
GeneGregory's Avatar
GeneGregory
A/T column shifter
The collar for my shifter is all worn out and the roll pin is about to fall out. I guess I need to get a new collar , pin and plastic bushing. Should I get a new shift lever also? Is their any thing special I need to know about taking it apart and putting it back together? 1979 F350 column shift A/T no tilt.
Old Jan 24, 2024 | 08:24 AM
wyrm73's Avatar
wyrm73
The shift lever to my knowledge is not reproduced, so you would have to find a good used one. Mine was worn pretty bad too, but the lever itself turned out to be fine- it was just the collar causing the issue. Might also double check your shift linkage and bushings as well as your steering column lower bushing. These are all on the usual suspects list for shifter slop.
Old Jan 24, 2024 | 09:38 AM
tbear853's Avatar
tbear853
I replaced my shift collar, it was cracked inside and the pivot hole was worn, but the lever, etc were unmarked. Mie is a '77, and I'm sure the '78/'79 are different.
btissaw
Jun 6, 2023 07:49 AM
pizza guy
May 20, 2011 11:03 AM
460
Oct 28, 2007 08:50 PM
laptopgeek
Aug 30, 2002 09:59 PM
