Windshield Wiper
Old Jan 21, 2024 | 07:15 AM
ADELEANDRE's Avatar
ADELEANDRE
Windshield Wiper
Hello, I don't understand how the windshield wiper motor is powered? the + comes where and the - where? I'm lost...
Unless I'm mistaken, I thought I read that the Windshield Wiper button works on the - but in this case where does the + come from?
As you will see in the drawing I have 3 wires coming from the motor and 1 wire with a round terminal, what does this one connect to?
For information it is a 2-position Windshield Wiper ****.
Thank you !
Old Jan 21, 2024 | 07:23 AM
ADELEANDRE's Avatar
ADELEANDRE
Old Jan 21, 2024 | 08:49 AM
ADELEANDRE's Avatar
ADELEANDRE
I found this diagram which I think would mean that the wire with the round terminal is to be connected to the +? do you confirm me?
Old Jan 21, 2024 | 10:16 AM
TA455HO's Avatar
TA455HO
Lead Gopher
The diagram is not quite correct in my mind - the black wire itself only goes to the motor and doesn't connect to the battery directly.
The motor is negative grounded through its housing to the mounting bracket - then to the cab metal through the mounting surfaces and bolts - which is connected to chassis ground.
The 12V+ positive wire to the switch is the one with the round terminal. That wire - labeled Green-Orange on my wiring diagram - is designed to go on the center post of the ignition switch - also called the A or Accessories connection.
Old Jan 21, 2024 | 10:59 AM
ADELEANDRE's Avatar
ADELEANDRE
Ah je comprends mieux ! donc la borne ronde c'est pour le + 12V, ensuite il faut redistribuer le + dans le connecteur mais je ne sais pas vers quel fil.
L'essentiel pour mon câblage c'est qu'il me suffit de brancher le + sur la borne ronde et le - se fait sur le corps moteur.
Thank you very much
Now, Je dois juste comprendre comment fonctionne le branchement du chauffage et tout ira bien
Old Jan 21, 2024 | 11:11 AM
TA455HO's Avatar
TA455HO
Lead Gopher
Je m’attendrais à ce que la distribution électrique des fils se produise à l’intérieur du connecteur. Prenez une photo du côté du connecteur où les fils y pénètrent et publiez-la s’il vous plaît.
Old Jan 21, 2024 | 11:28 AM
ADELEANDRE's Avatar
ADELEANDRE
here is the connector
Old Jan 21, 2024 | 12:18 PM
TA455HO's Avatar
TA455HO
Lead Gopher
I looked back at my wiring diagram and the windshield wiper switch itself takes care of the routing depending on if it is set to 'slow' or 'fast'. What you have should be plug and play I would think.
RunRed
Mar 25, 2007 12:41 PM
TexasGuy001
Aug 31, 2006 07:28 PM
sarkis
Aerostar
Sep 29, 2004 01:14 AM
beartracks
Apr 6, 2001 04:05 PM
