Major miss
Old Jan 19, 2024 | 07:18 PM
luvemhot's Avatar
luvemhot
Major miss
After my truck warms up about 20 minutes it develops a miss enough so that is barley runes. I have replaced the HPOP, IPR, Injector drive nodule.
Not sure my next move, but thinking changing the value cover gaskets. then Injectors.
Thanks in advance for your help
Old Jan 20, 2024 | 12:35 AM
Jimmy's Pilot Service's Avatar
Veteran: Navy
I can feel the heat of the shotgun barrel from here after that...
Absolutely no mention of pulling codes or running the tests that FORScan or FORScan LITE has the ability to do. Use the OBD II reader they tell you to use.
Start there or reload.
Old Jan 20, 2024 | 07:01 AM
RacinJasonWV's Avatar
RacinJasonWV
I agree with Jimmy. Let’s do some diagnostics before swapping any more parts.
I’d start with checking the fuel pressure. https://www.ford-trucks.com/forums/a...4&d=1592859516
Old Jan 20, 2024 | 08:23 AM
97-psd's Avatar
97-psd
CEL come on?
you Can also perform a test through the IDM connector to check the integrity of the wiring
Old Jan 20, 2024 | 09:18 AM
Kwikkordead's Avatar
Kwikkordead
HAHAHAHAHA!
And since we're skeet shooting here, I'll bet on a worn out fuel injector being the culprit. Works ok with morning thick, cold oil, but get it warmed up and the pressure bleeds off inside or something like that and now it cannot do a good job with minute injections like what is required at idle speed and load.
Old Jan 20, 2024 | 10:15 AM
hobohilton's Avatar
hobohilton
I've known a few guys who turned engines into boat anchors during a prolonged diagnostic period of time.
Barley runs is a Red Flag.
Get some qualified help before you ruin a rebuildable engine.
Old Jan 20, 2024 | 12:14 PM
brandonrr's Avatar
brandonrr
Have you tried pushing on the 42 pin connectors on the valve covers while it is misfiring? If one of your 42 pin (UVCH) connectors is loose, it'll only run on 4 cylinders and will smooth back out when when you push on the loose connector.
Another quick thing to check is blowby. Have you checked the blowby yet? A decent amount of white vapor is okay, but any noticable pressure coming out is bad.
If you haven't already, check out the tech folder that is stickied in this forum. There's a ton of good info there that could help with diagnosing your truck.
Old Jan 20, 2024 | 05:31 PM
luvemhot's Avatar
luvemhot
forgot to say no codes. will get back with I get a code reader on it.
thanks for the reply's.
Jason Trammell
Jun 30, 2022 05:07 PM
hstechfl
Jul 2, 2021 07:49 AM
cabloom300
Jan 24, 2014 06:39 PM
Paxdad
Jul 1, 2010 02:56 PM
shocktower
Modular V8 (4.6L, 5.4L)
Jun 5, 2004 04:15 PM
