Still getting codes
Old Mar 8, 2004 | 10:19 PM
shocktower's Avatar
shocktower
Still getting codes
Help me ,I put a reader on the out put and here`s the codes I get P0302 P0301 ,so I change the coils and plugs and I still get this code ,help me
Old Mar 8, 2004 | 11:35 PM
krunker's Avatar
krunker
the first thing I would do is make sure the injectors are functioning. To check this use a mechanics stethiscope and listen for clicking. If you don't have one, put your finger on them and see if you can feel the click.
Old Mar 9, 2004 | 09:22 AM
shocktower's Avatar
shocktower
Thank you
I will try this
Old Mar 10, 2004 | 10:46 PM
03f150man's Avatar
03f150man
unplug the injectors one at a time with the engine running. If you unplug one and the engine runs the same, then suspect that injector or something with that cylinder.
Old Mar 16, 2004 | 06:33 AM
FordLariat's Avatar
FordLariat
Before I replaced the injectors, I would change out the fuel filter. I had a misfire and went through several sets of plugs and wires and some serious stress and cussing until I found this out. Just wasn't letting enough fuel through, and it only hurt one cylinder.
Old Mar 19, 2004 | 09:26 PM
problmsolver's Avatar
problmsolver
ck compression!!!! don't forget u have to have fuel, fire , and compression. i really have only seen a couple injectors bad, i also have seen a few intake vavles worp.
Old May 8, 2004 | 12:51 PM
dasnuke's Avatar
dasnuke
Exclamation How in the world . . .
do you get to those wires and plugs? Every thing seems to be at the back of, under and behind the engine?
the scanner reads that there are two messages, but they both read the same (just bought it, so I may not be reading it right) when I press the down arrow. Actron OBD II cp91135
I am a vertically and girthly challenged kinda guy; I hope that I can get to #2, but should I try and replace them all?
Originally Posted by shocktower
Help me ,I put a reader on the out put and here`s the codes I get P0302 P0301 ,so I change the coils and plugs and I still get this code , help me
Old May 8, 2004 | 03:07 PM
LxMan1's Avatar
LxMan1
If you go to the 97-03 F150 forum farther up the list, go to the FAQ thread, there is a good write up on changing the plugs.
Old May 8, 2004 | 11:49 PM
dasnuke's Avatar
dasnuke
Thumbs up Thanks LxMan1
LxMan1,
Thank you for the heads up. I guess that I did not search in the right places.
Is there a forum area that discusses OBD Scan Tools?
Thanks,
trav
Old Jun 5, 2004 | 04:15 PM
dasnuke's Avatar
dasnuke
Exclamation Very Interesting
The filter impacted only one cylinder? That is interesting.
I replaced the filter first thing, and the problem continued. I thought silly me, the filter should have impacted more than one cylinder. Oh well, live and learn. The only problem I had with the filter was getting it out of that big old clamp (well and breaking the sissor type fuel line disconnect tool)
