Injector problem but no codes
Old Jun 29, 2022 | 10:06 PM
Jason Trammell's Avatar
Jason Trammell
8th Gear
I have pro line auto enginunity but for some reason I can't figure it out any suggestions will be greatly appreciated I've tried cutting ymthe injectors off one by one nothing different done the buzz test all fine their film 48 v ipr fine
Old Jun 30, 2022 | 10:45 AM
BLADE35's Avatar
BLADE35
Are you getting air bubbles in upper fuel filter during crank with yellow wire
Old Jun 30, 2022 | 10:46 AM
BLADE35's Avatar
BLADE35
The AE injector seams questionable at best from other threads
Old Jun 30, 2022 | 02:11 PM
Yahiko's Avatar
Yahiko
Benny is correct.
AE won't do an uncompensated power balance.
Then on top of that an injector must be nearly dead for it to report any problems.
Get your hands on Forscan laptop version with the wired OBD2 connection.
Ir you can try and find one of the good VCM2 clones.
Old Jun 30, 2022 | 02:44 PM
bismic's Avatar
bismic
Unfortunately even the wired (USB) version of ForScan (full version) won't do an uncompensated Power Balance test.
Hate to say this, but there's only so much you can check on injector contribution problems without dealer level diagnostic equipment. An injector could easily cause the contribution issue(s), but so could a lot of other things. When you have only contribution codes, or worse yet - only rough running conditions, generally you have only a couple of choices: 1) Take it in for uncompensated injector Power Balance testing, or 2) firing parts at it, which could possibly cost more than having it diagnosed correctly.
As an FYI - the dealership should run the Power Balance on a cold engine.
Typically, the only parameters that you're capable of viewing that MIGHT help are FICM volts (MPower, LPower, and VPower), ICP pressure, ICP voltage and IPR % duty cycle. Try to watch these parameters with the problem occurring. If you see ICP sensor voltage acting erratically, or IPR % duty cycle maxing out at wot, then you probably have an issue in the High Pressure Oil System.
Another thing to check is fuel pressure, but that requires an "add-on" sensor AND gauge. ALWAYS monitor with the problem occurring if possible.
Old Jun 30, 2022 | 04:34 PM
xcrsp440's Avatar
xcrsp440
Why do you think you have an injector issue? What symptoms are occurring?
Old Jun 30, 2022 | 05:07 PM
bismic's Avatar
bismic
Some common themes .......
https://www.ford-trucks.com/forums/1...preciated.html
cookingguy
Dec 6, 2015 12:20 PM
cabloom300
Jan 24, 2014 06:39 PM
bluesmanmike5
Sep 14, 2012 05:37 AM
dbarnett42
Oct 5, 2011 06:53 PM
jmaskew
Aug 21, 2011 05:47 AM
