01 EX
Old Jan 16, 2024 | 08:22 AM
det56's Avatar
det56
1st Gear
01 EX
When I start my engine (V10) in the morning I seem to have a sound like a miss. But it is not missing. It runs very smooth. Once it warms up it isn’t as bad but it is still there. I’ve only owned it a couple weeks now. This is one of the cleanest used trucks I’ve ever bought. From underneath to the top. It looks like it was taken care of by whoever owned it in the past. But that sound bothers me. Any idea? Thanks
Old Jan 16, 2024 | 09:21 AM
RLC2020's Avatar
RLC2020
4wd Low
Mine has a slight exhaust manifold leak when I first start it. Once it warms up it seals up and doesn't do it anymore. Sounds like a miss at idle, but it's just a leak. It could be that
Old Jan 16, 2024 | 09:42 AM
projectSHO89's Avatar
projectSHO89
Could easily be the exhaust leak mentioned. Mine's been like that for going on 10 years. Since it hasn't gotten worse, I haven't tackled the problem.
Also, check all of your spark plugs to make sure they're not loose. You can put a fingertip on top of each COP in turn and see whether it's bouncing or still. You want them to be still. Any that are loose need to be addressed immediately before they blow.
Old Jan 17, 2024 | 12:51 PM
MoBill122's Avatar
MoBill122
Papa Smurf
Look for any water collecting in spark plug holes. The intake manifold leaks a lot on these gas burners.
Old Feb 2, 2024 | 12:37 PM
bbock's Avatar
bbock
my 2001 10 cylinder EX seems to do the same thing. Is yours gas or Diesal? Not sure if that would make a difference🤣
Old Feb 2, 2024 | 01:53 PM
RLC2020's Avatar
RLC2020
4wd Low
Mine is the gas V10 with 210k on the clock. If the leak gets worse I'll deal with it, but it's not terrible.
Old Feb 2, 2024 | 02:10 PM
bbock's Avatar
bbock
oh ok mine is the same 2001V 10 has 177 on it but it seems to be the same after a few minutes. I barely hear it anymore. I also have the pinion seal sound in the back but it’s really not terrible not the noise people say they get when they have to definitely replace it right away, one mechanic I had said just keep an eye on the fluid as long as it’s Not leaking and you don’t mind the slight whine noise you’re fine that was over 10 years ago . New mechanic guy said if it gets louder you definitely need to replace it.. I’ve had the fluid changed in the rear end a few times I barely put 5000 a year on it now or less …no leaks so holding off for now
thanks for the reply👍👍
Old Feb 4, 2024 | 10:03 PM
bajaphile's Avatar
bajaphile
You should be able to look in the wheel wells and inspect the exhaust manifold studs and nuts. See how many are missing...
If not exhaust manifold leak, try cleaning the MAF and check for any obvious vacuum leaks. The PCV hose at the 90deg bend as it enters the intake (on top of engine) is a common failure point.
Old Feb 4, 2024 | 11:25 PM
bbock's Avatar
bbock
Thanks for the reply. I will try to do that.
Outlaw Pythons
Modular V10 (6.8l)
Apr 8, 2010 09:07 PM
cdrmotorsports
Modular V10 (6.8l)
Jun 29, 2007 04:00 PM
DUB85
Modular V10 (6.8l)
Feb 25, 2006 11:51 AM
lovzmud
Modular V10 (6.8l)
May 19, 2003 09:52 AM
odinmurphy
Aug 8, 2002 12:13 PM
