Transfer case compatibility
Old Jan 12, 2024 | 02:59 PM
G2IC_Wraith's Avatar
G2IC_Wraith
Question Transfer case compatibility
I looked around & didn't see what I was looking for so if this was covered, feel free to point to the thread.
Are the transfer cases all the same including the gearing for 04'-08'?
Second, are the electronic & manual transfer cases interchangeable?
In other words, if I had a manual xfer case in my truck & all I could get is one that was out of an electronic shift truck, are they compatible?
Can you just take the electronic motor off & swap your manual stick over to it?
The "bigger picture" to this is I am considering a cab-swap & many of the models have electronic shift transfer cases where mine is manual.
The answers to the above questions would let me know if I have to take the transfer case with the cab. Assuming all the interior & wiring came over with the "new" cab.
I am sure I could just cut the floor for the shifter but I figured why do that if I could just swap the case or just the electronic shift motor over to my current xfer case.
Old Jan 19, 2024 | 04:00 PM
G2IC_Wraith
Really? No one has had the 2 transfer cases side by side or swapped them?
Where are all the geese-monkeys? We can't just have keyboard commandos on here.
Ronniewhite
2009 - 2014 F150
Aug 8, 2023 10:07 AM
BubbajonL
Sep 8, 2022 08:39 PM
17fordguy
Jun 9, 2009 08:15 AM
eriojas
1978 - 1996 Big Bronco
Feb 24, 2004 10:05 PM
baw289
Jan 13, 2004 08:51 PM
