1978 - 1996 Big Bronco
Transfer case swap
Old Jan 13, 2004 | 07:55 PM
baw289's Avatar
baw289
Transfer case swap
I have a 87 Bronco with a BW1356 transfer case. Im tired of the 4x4 not working, which manual transfer case will bolt up to it? Also what do I need for linkage and everything else? Anyone thats looking for a shift motor for a full size bronco let me know, its brand new, cost me a fortune, I'll let it go cheap.
Old Jan 13, 2004 | 08:51 PM
Lobuck76's Avatar
Lobuck76
same year, bw 1356 manual shift should.Up to 96 I believe according to folks on this forum that know. Make sure output is same. I had a hard time finding one with flange on back. Get the shifter,boot, linkage. Look at your trans adapter and see if it is tapped/ threaded for shifter to mount up. There is alot of good info in the searches on transfer case swaps. just search "transfer case" or "BW 1356". Ron
