have a 92 eddie bauer with electric shift transfer case( does not work properly), found a 91 junked bronco with the manual transfer case, anyone know if its an easy swap?
When \ if you get the t-case. Try to get the floor pan also. It already has the shifter cut out. Should just have a ring of screws holding it in. Hope this helps. Ed
Curious , whats wrong with the transfer case in it now shift motor?.Theres a link that easily helps u repair your original shift motor that engages your case to 4x4 checks and diagnostics. TR
i've checked the motor and it works fine when connected directly to 12v power, but when everything is hooked up, it only moves to 4x4, but you press the 4low button and nothing happens, press the 4x4 button and goes back to 2wd, i thinks its the cintrol module, but where i haven't been able to find another control module to see if thats the problem, any suggestions?
Originally posted by eriojas i've checked the motor and it works fine when connected directly to 12v power, but when everything is hooked up, it only moves to 4x4, but you press the 4low button and nothing happens, press the 4x4 button and goes back to 2wd, i thinks its the cintrol module, but where i haven't been able to find another control module to see if thats the problem, any suggestions?
