I got my first bullnose truck (1986 F-150 RWD 300 I6) a couple months back and have done a lot of repairs, but there's one thing that really bugs me... when I'm moving, there's a repeating squeak that sounds like it's coming from either the front driver side wheel or something nearby, and it gets louder and faster the faster the truck is moving irrespective of RPMs. I thought it might be the bearing(s) going dry or something so I went ahead and replaced the bearings and grease seals on both front wheels, adding plenty of new lithium grease. That didn't do anything to fix the noise, and I'm stumped. Putting on the brakes doesn't quiet it down at all, and all four pads are still good. Any ideas on what I should check next? Thank you!
-Isaac
Is it louder when on a bumpy route? Might be on the suspension. Try a step ladder next to the fender and get your weight positioned so you can press down and release the fender and get it rocking best you can. You'll be fighting the shock and you can test your shock at the same time. A worn shock could squeak as well.
You can tell if it's the driveline/u-joints. Go slowly till it squeaks. While it is squeaking, try to visualize the tires. They are rotating slowly. The driveshaft will be turning 3.5 to 4 times faster than the tires. So you should be able to determine from that, is it a slower squeak which would be the tires/brakes, or a faster squeak which would be the u-joints. The u-joints are known to squeak when they get dry.
I was also thinking Ujoints.
Most of the time they make more noise when under power like taking off from a stop but can make noise just holding speed.
Most of the time I say it sounds like a bird chirping and the faster you go the faster the chirping.
When they get really bad they will vibrate sometimes not making noise and the drive shaft will fall out.
This can be bad if it is the front Ujoint as the shaft can dig in flipping the truck over.
If you find it only makes noise when going over bumps ro when you were pushing up & down on the fenders, get some WD-40 or the like.
Spray 1 rubber bushing at a time till the noise stops and that is the bushing that needs looking into.
You should have 2 in the center for the beams and the 2 radius arm bushings.
If they were replaced with Poly bushings someone did not use the Poly grease with them.
I have Poly bushings up front and used the grease and no noise from them at all.
Dave ----
I wonder if you have sealed U-joints or greasable? If greasable they need a shot of grease every 3,000 miles. For sealed they might not make any noise before they come apart. That sound is more like wobble wobble wobble.
If they are factory u-joints, they are sealed. Sometimes you can tell also if they are getting ready to go by carefully examining the area around the joint itself. If you see a orange powder around some the u-joint pieces, that is a sure sign it's on it's way out.
-Isaac
check the brake rotor dust cover to see if it is rubbing the rotor. That will make a squeaky noise if lightly rubbing.
