Grinding Noise
Old Dec 9, 2012 | 10:47 PM
shawgf's Avatar
shawgf
Grinding Noise
I have a 76 crew cab 2wd that has developed a grinding noise at lower speeds 0-40 KPH. It vibrates the whole cab. It sounds like a rotating grind with a high-low sound. The truck is well maintained and I have changed a number of parts to solve this problem in the last six months with no success.
Parts replaced or new
Transmission rebuild 2 years ago (C6)
New wheels bearings all around
New brakes all around
New U-joints and center bearing
Rear diff was opened up and inspected. looked ok no filings
I am hoping that my transmission is not going bad truck is driven very little. I am starting to thing it might be worn motor mounts.(There is no clunking noise when you put it into gear). Truck makes noise when you put it into neutral when driving. The noise is much worse after I have driven it on the highway.
Any help would would be great.
Old Dec 9, 2012 | 10:49 PM
jetrinka's Avatar
jetrinka
Any way you could put it up on a pair of jackstands and have someone drive it while you listen for the noise underneath?
Old Dec 9, 2012 | 11:59 PM
VocaTexas's Avatar
VocaTexas
Have you checked your wheel bearings? A bad wheel bearing will make a grinding sound. You sure don't want to lose one driving, trust me.
Old Dec 10, 2012 | 12:09 AM
shawgf's Avatar
shawgf
I tried putting it up on jack stands did not make the noise and the truck has new wheel bearings all around
Old Dec 10, 2012 | 12:23 AM
jetrinka's Avatar
jetrinka
How did the axle shafts look when you did the bearings?
Old Dec 10, 2012 | 12:45 AM
shawgf's Avatar
shawgf
I do not remember what the rear shaft condition was like nor did I look, when I did the brakes.
caprang
Jun 7, 2011 10:36 PM
midnight1967
Feb 12, 2011 04:37 PM
fawey1
1983 - 2012 Ranger & B-Series
Oct 23, 2008 07:57 AM
savage250
Mar 24, 2007 09:08 PM
