Speedometer Needle Bouncing
Old Jan 6, 2024 | 05:44 AM
ranger140892's Avatar
ranger140892
Grumpy goat
Mine used to bounce at slow driving speed, and when I hit bumps. The polymer drive gear was worn down. It's an easy swap on a NP205 transfer case. I have no experience swapping the gear on other transfer cases, or transmissions.
It's easy to see how that worn down center would allow the driven gear on the cable to skip.
New drive gear compared to old one.
Old Jan 6, 2024 | 01:45 PM
1TonBasecamp's Avatar
1TonBasecamp
Good idea! At the very least, it's an easy thing to check. If it's in good shape, you only spent a few minutes and some greasy hands. But if it's bad, it's an inexpensive fix.
Even if it didn't get rid of the problem, it would get rid of one variable.
Paul
Old Jan 6, 2024 | 02:48 PM
redroad's Avatar
redroad
Paul
Those friggin' variables will get you every time if you dom't have your wits' about you.
Old Jan 7, 2024 | 05:32 AM
ranger140892
Grumpy goat
If only my 7th grade algebra teacher had properly explained what a "variable" is. Actually, she probably did,...a hundred times.
WYO6.7
Feb 11, 2021 03:14 PM
fordf348
Aug 18, 2019 12:24 PM
vax1ne
Escape & Escape Hybrid
Nov 28, 2005 10:09 AM
omnithesis
Aftermarket Products
Jun 2, 2004 02:48 PM
f100guy
Electrical Systems/Wiring
Nov 27, 2003 04:55 PM
