Boost leak problems
Old Dec 22, 2023 | 08:53 AM
Ashton_1012's Avatar
Ashton_1012
Boost leak problems
Hey everyone
I’ve spent the last few weeks diagnosing boost leaks, and installing a new KC Stage 1 turbo on my 7.3….
got everything back together and did another boost leak test to ensure I got everything together ok.
problem I’m having is now when I pressurize the boost system, I get massive air coming out the CCV vent and oil dipstick. Everything I’m reading says bad rings. My truck fires up on cold starts just fine. It runs great. I can’t imagine I have bad rings but I’m stressing about it. Anything else that can cause air to pressurize the crank case? Maybe valves weren’t seated? I didn’t try turning the engine and pressurizing again to see if it changes. When I did this prior to replacing the turbo I didn’t have this problem.
any advice ?
Old Dec 22, 2023 | 09:36 AM
knottyrope's Avatar
knottyrope
I would do a compression test
turn crank 90 and see if it still blows out fast
Old Dec 22, 2023 | 11:37 AM
Ashton_1012
Project for another day, unfortunately I don’t have the time right now!
I have absolutely zero blow by, both on cold starts and when it’s warm… I guess I’ll just have to run it and when I have time I’ll hook it up for a compression test
Old Dec 22, 2023 | 11:44 AM
tjc transport's Avatar
tjc transport
i ain't rite
when you do the boost leak test you eliminate the CCV from the system, correct?
Old Dec 22, 2023 | 12:05 PM
Ashton_1012
Correct, I had the CCV disconnected
Old Dec 22, 2023 | 07:40 PM
z31freakify's Avatar
z31freakify
any advice ?
Maybe the air pressure is going thru the turbo oil seals?
DanielT28
May 29, 2019 12:17 PM
helloimjason
13
Apr 26, 2017 10:42 PM
Highridge
Aug 18, 2010 08:58 PM
WideOpenFord
Nov 22, 2009 01:12 PM
mndiesel
17
Nov 5, 2007 06:04 PM
