need electrical help please
Old Jan 14, 2024 | 04:18 PM
gweedo295's Avatar
gweedo295
UPDATE: I figured out the problem. The new distributor rotor looked the same and it was the one it called for the new distributor cap. Everything I tested said the distributor was the issue. I decided to measure the new rotor to the old one. The new rotor didn't sit as low as the old one. I put the old rotor in and it fired right up. Parked for 20-years and now it has a new life. Thank goodness. Master cylinder is leaking but that's okay, it's all being replaced anyhow. I've done the heads timing chain pump etc. now onto the brakes.
Thanks again for the responses.
paulstruck
Nov 24, 2024 04:41 PM
Idaho Highboy
Sep 30, 2020 05:03 PM
jmlanc72
24
Aug 28, 2019 06:09 AM
littlehorse
Jul 15, 2019 01:45 PM
Notmeofficer
Jul 18, 2016 05:40 PM
