Sponsored by: Real Truck
sticking brakes
Old Dec 22, 2023 | 04:44 AM
samsdad02's Avatar
samsdad02
New MC and booster in October.
That caliper is the oldest on the X but still less than a year old.
When I bleed brakes I use my breaker bar from the seat to the pedal. Crack the bleeder, release the pedal and put the breaker back.
Old Dec 22, 2023 | 12:13 PM
samsdad02's Avatar
samsdad02
Well that was fun. Took the left rear apart, felt ok. Pumped the brakes a little to get the pistons out some and the lower moved less than the upper. Grabbed my large channel locks to give them a squeeze. The lower one was really stiff, the upper was fine. Put a new caliper/bracket on.
The brake fluid that I drained out of the old caliper was weird. It was slightly discolored but not far off of new fluid. But it seemed slightly gelled or at least thicker than normal brake fluid. The fluid I bled out of the new caliper was fine. The fluid has only been in there since October when I did the MC and booster. And I bled 2 large containers of brake fluid thru because of the goo that was in the old MC.
I dunno. Hopefully I won't be doing anymore brakes until spring.
Old Dec 23, 2023 | 01:52 AM
INFRNL's Avatar
INFRNL
Glad you got it.
you know there is an easier way to bleed brakes yourself. Also, brake fluid is the most overlooked part of a brake system.
Maybe your lines are in bad shape internally and the new fluid loosened some of it up causing the weird fluid, IDK
Old Dec 23, 2023 | 08:46 AM
samsdad02's Avatar
samsdad02
Originally Posted by INFRNL
Glad you got it.
I don't know what happens to brake fluid when it gets really hot. It's been a week or so of driving with the caliper hanging up.
Old Dec 28, 2023 | 08:01 PM
eddiemeixell's Avatar
eddiemeixell
4wd High
Originally Posted by samsdad02
Looking for opinions.
Have become tired of the constant brakes hanging up. I figured every time I switch from winter to summer tires and back breaking down the calipers and brackets to clean and grease the slides would be enough. Apparently not.
I am thinking about drilling and tapping a grease fitting on the bracket and every 3 months giving a pump or 2 of some high temp wheel bearing grease in.
Thoughts?
Does it sit a lot? They tend to get sticky when parked a lot
Old Dec 29, 2023 | 04:57 AM
samsdad02's Avatar
samsdad02
It gets driven at least 3 times a week.
Spring and fall when I switch tires the slides get cleaned and lubed. Still doesn't seem to be enough.
Switching the type of lube to AGS sil-glyde. See if that helps.
Old Dec 29, 2023 | 11:58 AM
super 6.8's Avatar
super 6.8
I am wondering if you have something geometrically off. Like maybe bent caliper brackets or something that is causing the binding.
You are having a lot more issues than normal and have been really trying to fix the issue.
I hope you can figure it out.
Old Dec 29, 2023 | 04:16 PM
redford's Avatar
redford
FTE Leadership Emeritus
How do your flex hoses look?
Old Dec 30, 2023 | 05:18 AM
samsdad02's Avatar
samsdad02
Flex hoses were replaced within the past year.
Old Dec 30, 2023 | 05:20 AM
samsdad02's Avatar
samsdad02
All of the caliper brackets have been replaced when I have done calipers. So on third set.
Old Feb 5, 2024 | 03:29 PM
samsdad02's Avatar
samsdad02
Figured I would update as I'm having abs issues now.
No issues with brakes dragging or hanging up since I cleaned and re lubed with the AGS sli-glyde. Of course the abs is being stoopid. No light on the dash and no codes for about a week but anytime on the brakes below 10ish mph the abs goes nuts which is lotsa fun plowing driveways.
Finally got the abs light on put forscan on it. left front abs messing up. Wheel bearings are tight so ordered new wires. Hey look! the left front dust shield is missing and so is the better part of the one of the ujoint cups!
Replaced all that junk but haven't had a chance to drive it yet.
Shattered
Nov 19, 2015 09:08 PM
77hb
Aug 16, 2005 07:39 PM
keithf
Oil & Lubrication
Feb 12, 2003 08:17 PM
jmacjr1125
Dec 11, 2001 07:02 PM
