Battery question. Why?
Old Dec 15, 2023 | 09:25 PM
black & blue 78/9's Avatar
black & blue 78/9
Why does the positive terminal keep corroding? I clean with baking soda and the blue STARTS coming back in 2-4 weeks. This much takes longer. Is there something else causing this? Bad cable ends, bad grounds, age .....what? Thanks for the help. Battery is 39 months old.
Old Dec 15, 2023 | 10:04 PM
Jimmy's Pilot Service's Avatar
Veteran: Navy
The photo indicates you have the same issue on both sides.
Once the cable has been exposed to the corrosive gasses from the battery for what ever reason, there is only one fix.
Replace the cable, as the cable has internal corrosion form the gasses. You can not fix this.
Your battery started this issue. Replace it. Once it starts venting due to a crack or bad seal that you can not see it will keep causing the issue. Or keep fighting the battle.
New cable and clamps.
Clean the battery thoroughly.
Use battery conductive grease.
Use the felt battery pads.
Old Dec 16, 2023 | 12:15 AM
1TonBasecamp's Avatar
1TonBasecamp
And because it’s not a sealed battery, make sure that it’s not slightly overcharging when vehicle is running.
If you’re getting a slight overcharge, it’s more likely to off gas through the vents and make this problem worse.
Otherwise everything that was just said. Cables are already compromised, and maybe the battery was overfilled at some point.
Old Dec 16, 2023 | 07:10 AM
crazy96863's Avatar
crazy96863
A film of dielectric grease on the battery terminal and cable end should end the madness.
Old Dec 16, 2023 | 07:35 AM
ranger140892's Avatar
ranger140892
Grumpy goat
CRC makes a couple of products I use on all my batteries. A battery post cleaner spray, and a battery post protector spray. They work. But yeah, you should preplace that positive cable.
Old Dec 16, 2023 | 08:06 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
X3 replace your cables and when you're done you can use a dielectric grease or just regular grease and just glob it all over the cable connection area and the post to the battery, no more corrosion problems.
Old Dec 16, 2023 | 09:08 AM
Mark8man's Avatar
Mark8man
My experience with recurring post corrosion is the seal around the post is bad. No way to fix other than replace battery. I use a terminal sealant but I have had batteries in various cars & equipment that never had any corrosion preventive measures applied and they never corroded.
Old Dec 16, 2023 | 09:09 AM
cb_13's Avatar
cb_13
If it’s reappearing that soon you may have a battery case issue. Check where the lead terminal protrudes from the plastic case to see if it’s actually an acid leak from that spot.
If it’s a very minor leak you may be able to stop it with some really good battery pads like BG or Noco. If it’s a decent leak battery replacement is the only solution. The lead acid Motorcraft batteries are built by Johnson Controls and have had case integrity issue for the last few years. Johnson Controls builds a ton of batteries, if that Interstate battery is a couple years old they built it as well. Newer Interstates are usually Exide built now.
Old Dec 17, 2023 | 09:39 AM
mark a.'s Avatar
mark a.
I used to have that problem and it didn't matter which battery, they all did it. I added a motor to frame ground, radiator support to battery ground, bed to frame ground. There should already be engine to firewall ground and hood to firewall. After that no battery has ever done it again.
Old Dec 17, 2023 | 09:47 AM
ranger140892
Grumpy goat
You're right. Have good grounds, and lots of 'em!
Old Dec 17, 2023 | 10:12 AM
tbear853's Avatar
tbear853
I have on occasion used those red and green round washer things, but my best luck is after a good cleaning with baking soda, rinse, dry, and then a coat of paint or battery terminal protector after reconnected. I just spray red on the pos, black on the neg.
Old Dec 21, 2023 | 04:13 PM
black & blue 78/9
Thanks to all for the answers. I will try them.
dannac
2015 - 2020 F150
39
Oct 6, 2024 04:54 PM
mwoj
Jun 20, 2021 08:11 PM
Big Norm
Oct 14, 2019 02:54 PM
nnero
2009 - 2014 F150
Aug 4, 2014 05:29 PM
BIGRED 7.3L
16
Oct 5, 2011 12:01 PM
