2001 7.3 diesel reverse.
I was told reverse going out is not uncommon, and that it is geared high for backing uphill with a load on it.
Well that's exactly what I do, my driveway is steep uphill so backing in with my backhoe on the trailer is hard and if I have a load in the dump body it is a heavy push.
heavy.I read that others shift to 4WD LOW to back up hills. That makes sense to me but my driveway is asphalt, it will surly put a bind in the drive train in 4x4 low, it seems like I would be better to go to low with my hubs unlocked to reduce binding but I'm unsure if that could put unnecessary force in a spot I'm not thinking of.
I would be glad for some insight and opinions please.
My owners manual states, (I have manual hubs), that engaging the transfer case with the hubs in the unlocked position will damage the transfer case.
Curious though,,,,,,,if backing in a straight line, why can't you use 4X4? In 4X4 on pavement, its the act of turning the wheel that makes the front diff bind.
Just looking for clarification.
If you are stopped when you engage 4WD, no harm will be done. I run my ESOF truck (with manual Milemarker hubs) in 2-Low frequently. And yes, if you go in a straight line, you can use 4WD on dry pavement in a very limited way.
When you put your truck into 4 wheel drive, 2 things happen.
First, the transfer case applies power to the front drive shaft. This power goes to the front differential and to the front axle shafts.
Second, the hubs lock the wheels to the axle shafts. This allows the power in the axles to be applied to the road.
Engaging a 4 wheel drive mode but not locking the hubs means at worst your front axle shafts will spin without power being applied to the ground. No mechanical part will be forced to do something it wasn’t designed to do in the first place.
Backing up in 4 wheel drive, in a straight line, is OK. My problem is that my trailer reversing is almost never in a straight line. I’ll always take up 12 feet of a 10 foot driveway.
The issue is the rear axle and driveshaft. By putting the transfer case in low, the torque sent to the driveshaft and rear axle is multiplied by the low range ratio of 2.7:1. So the driveshaft and axle can see 2.7 times the torque they were designed to handle. Will that break something? I don't have that answer, but it would sure worry me if it were my truck.
If I'm backing up hill with a load in the back, or if Im backing uphill with the trailer (empty or loaded) I really have to give her the juice in 2WD, it seems to be reving to much and slipping the clutches in the auto transmission.
Going into low range the motor is moving the truck and load uphill right off idle. Nice and slow total control. Hopefully I never have the pleasure of replacing the transmission again.
Photos are of the 87 F-350 6.9 IDI ZF-5. It doesnt like reverse either but it's 2WD so...heavy loads in forward only.
Under those conditions if the clutches are really slipping you've already destroyed the transmission. Two to three seconds of slipping under a heavy load will destroy the clutch. What you are seeing is the torque converter slipping, and that is what it is designed to do.
