Broken boss
Old Dec 2, 2023 | 12:20 PM
john jamieson's Avatar
john jamieson
Broken boss
I'm in the process of installing the bell housing. While torqueing the 6 bolts that hold it to the block, the lower right boss cracked in half and fell off. The flange is still on the block, just the raised threaded portion broke in half. This is in my '64 F250 that had a 390 swapped into it.
Do I worry about it? This truck doesn't get a lot of use.
Thanks. John
Old Dec 2, 2023 | 04:10 PM
DaveMcLain's Avatar
DaveMcLain
Would it be possible to use a longer bolt and put a nut on the back side?
Old Dec 2, 2023 | 06:10 PM
john jamieson
I'm not sure. It's the one below the starter. There isn't much room and it runs along the side the block. Maybe if I drill out the threads and am able to keep the broken piece in place, as a spacer.
Old Dec 2, 2023 | 06:49 PM
DaveMcLain's Avatar
DaveMcLain
The easiest and best way to repair the block would be to braze up a new boss and then redrill and tap a new bolt hole in the right location.
Old Dec 2, 2023 | 06:55 PM
runthatjunk's Avatar
runthatjunk
It'll be fine. Unless it was cracked before hand it shouldn't have broke though, you sure everything is drawing together flat? That would be my only concern
Old Dec 3, 2023 | 02:56 PM
mark a.'s Avatar
mark a.
I wouldn't worry about it either.
Old Dec 3, 2023 | 09:05 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
All the bolts do is hold the block and bellhousing together - so long as the dowels are in place on either side there won't be any alignment issues.
memphisjewel
23
May 10, 2016 04:54 PM
Cougar54
20
Jan 10, 2015 06:07 PM
MER
Sep 17, 2008 08:59 PM
scottie2hottie
General Automotive Discussion
Jan 18, 2005 06:40 PM
gtex
Jan 16, 2003 10:04 PM
