General Automotive Discussion
Help any mopar fellas!
Old Jan 17, 2005 | 02:56 PM
scottie2hottie's Avatar
scottie2hottie
Will a 318 bolt to a slant 6 bellhousing? This is in a 78 1/2 4x4 Dodge pickup.
Thanks
Scott
Old Jan 17, 2005 | 04:49 PM
thunderguns71's Avatar
thunderguns71
Nope, the bellhousing on the six is different because the engine is slanted. You need to find a small block bellhousing.
Old Jan 17, 2005 | 05:32 PM
scottie2hottie
Much obliged!
Scott
Old Jan 18, 2005 | 09:08 AM
ggarrahan's Avatar
ggarrahan
If it's an automatic you need the whole small block transmission because the bell housing is not removeable, the transmission housing is a one piece casting, only the tailshaft housing is removeable. Also, there are 904 and 727 small block transmissions, the 727 is the heavy duty model.
Old Jan 18, 2005 | 05:33 PM
scottie2hottie
It's a 3 sp man with shift on the tree, I think it's a removable bellhousing...
Scott
Old Jan 18, 2005 | 06:40 PM
oldhalftons's Avatar
oldhalftons
you need a smallblock bellhousing and motor mounts and mount-to-engine brackets for a 318. 318 brackets can be shimmed to fit a 360, but 360 brackets will not work with a 318. they have to be truck brackets, car brackets won't work.
There are no frame towers to deal with.
The 318 must have a rear sump truck pan, a center sump car pan will not work.
If the bellhousing bolt pattern is almost completely round it is a big-block bellhousing.
If the bellhousing bolt pattern is less round with a pronounced starter bulge on the drivers side its a small-block bellhousing.
If it has the starter mounting above the centerline and really far over on the driver side it is a slant-6 bellhousing.
