Front Fuel Pump Noise
Old Nov 26, 2023 | 07:21 AM
blazerman07's Avatar
blazerman07
So I noticed yesterday that my front tank fuel pump makes a low whine while running. When I switched to the rear, the noise is gone. Fuel pressure holds steady at 31psi with vacuum and 41 without and same on both. A year and a half ago the dealer replaced the sending unit only and filler hose(kinked). I can't tell if it's a new noise or not. Never paid attention before as I was adding an adjustable regulator yesterday. Not sure if I should be worried or not.
1994 F250 7.5L
Old Nov 26, 2023 | 08:06 AM
jas88's Avatar
jas88
You should be able to hear either pump when it is running.
Old Nov 27, 2023 | 05:54 AM
manicmechanic007's Avatar
manicmechanic007
They get noisy as they start to wear out (way worse on the Chevs)
If you ever take an old one apart and inspect the commutator (brush to armature interface)
You will see extensive wear of the armature (causing the noise)
Old Nov 27, 2023 | 06:50 AM
blazerman07
That's what I am thinking. I am going to recheck today. Psi is the same on both just one is a little noisy.
Old Nov 27, 2023 | 09:29 AM
manicmechanic007
I would not replace it until it quits, but I would buy one now
Old Nov 27, 2023 | 12:41 PM
Junktownbill99's Avatar
Junktownbill99
1994 F250 7.5L
Mine are both noisy, front a little louder, but truck runs fine on either, (although front fuel gauge doesn't work) '91 f150
Edit: will the bed have to be pulled to replace them? I don't even have a garage, so it'd be ideal if it didn't.
Old Nov 27, 2023 | 01:59 PM
blazerman07
Not necessary to remove bed, but if doing both might be easier. I will go with the Delphi when it quits and may order it to have on hand. Thanks for the info.
Old Nov 27, 2023 | 10:52 PM
manicmechanic007
I sure would not worry, just plan. The pump could last for years and years noisy like that
Keep some fuel in the tank to keep it cool
Old Nov 27, 2023 | 10:59 PM
Junktownbill99
I know when my front tank is empty when the go pedal doesn't go anymore.
Flitastic
Jul 24, 2021 07:38 PM
cdat81986
Jun 4, 2011 06:23 PM
Redsearock
Jul 5, 2007 01:38 PM
heavyd86
Nov 15, 2005 07:34 PM
FalconYT
Jul 6, 2004 02:35 PM
