Your pic tells me I was looking at the right thing. I’ve cleaned that and it didn’t help. I did order a new one and I’ll install it on Saturday. I’ll also get an infrared thermometer as suggested. I really appreciate all your suggestions. I’ve got my friend helping me who mirrors all of your suggestions so I think between all of u I’m in good hands
When you are overheating it's very obvious with the hood up. You can feel the heat on your face. And if you can't lightly touch the top hose or thermo cap cause it's too hot to even lightly touch. The infrared thermometers are a handy tool too.
I was a dishwasher in a restaurant back in high school. The water temp in the washer was a scorching 180 degrees. So my fingers were calibrated at an early age!
Thank you! Do you recommend a specific aluminum radiator?
If anyone decides to upgrade to an Aluminum Rad with welded sides, be CAREFUL. There are a million stories(all makes and models) of poorly welded aluminum Rads. After an unreasonably short period of use, they may begin to leak. You can take it to a pro to weld the leaks shut, but it just raises a lot of red flags for the future. None of them are cheap, but definitely spend a little extra on a reputable manufacturer.
I second what was said before.... If it ain't broke, don't fix it. Keep the original Rad until your sure it is bad.
When you are refilling the cooling system on a coolant change you're pouring in cold coolant. You'll have some air trapped in various locations. But fill it to the top, cap it and start the engine. As the engine warms the coolant in the block will heat up the thermostat will open and circulation begins. You'll know it happens when the top hose gets hot. I let the engine run a little longer and then shut it off. The coolant in the radiator was cold and it's now entering a warm block transferring heat to the cold coolant but still not blazing hot. Yet the thermostat opened burping it. Since the entire cooling system doesn't get up to temp right away the cool down time is pretty short too. If you burp it just once and have at least a gallon in the overflow bottle you'll be good for a short trip. Later when the engine cools again there might be a small amount of room in the radiator. I also mark the level in the overflow bottle with a sharpie so I can see if it is taking coolant into the system. I usually put a gallon in the overflow and mark that. If it goes down I can add to the overflow to make it up.
that's the rest of the story...
Can you diagnose why my Overflow tank is always overflowing? My truck pushes the coolant past the Rad cap into the overflow until it begins to overflow. I have to top off my Rad every few drives.
how old is your radiator cap? what brand? I would start there.
Yes, the cap is a key element. It allows flow to the overflow bottle when pressure increases beyond the cap rating. Also allows reverse flow when the radiator goes low on coolant. If your overflow is constantly "overflowing" the cap may be weak or you are not getting adequate cooling. Another possibility is a blown head gasket where piston pressure is getting into the cooling system.
