2022 superduty locker?
Old Nov 12, 2023 | 05:33 PM
Leo21's Avatar
Leo21
2nd Gear
Unhappy 2022 superduty locker?
Hi, i have 2022 F250 Superduty 4x4 with open differential. some one know any locker o LSD available for my truck?
31 spline 3.31 and 10.50. thanks
Old Nov 12, 2023 | 08:07 PM
WXboy's Avatar
WXboy
Eaton/Detroit makes a locker and also a helical limited slip called the TrueTrac. A lot of people love the TrueTrac and I plan to have one installed in my axle as soon as I can afford it. I'm getting quotes of around $1,500 to get one installed.
Powertrax makes a helical limited slip also and it's a couple hundred bucks cheaper but I can't find any reviews on that one. It's called the Grip PRO.
Old Nov 12, 2023 | 08:10 PM
twobelugas's Avatar
twobelugas
ARB makes it for the 10.5 sterling as well.
Old Nov 12, 2023 | 08:48 PM
OBS460's Avatar
OBS460
The 10.5 has a factory available e-locker
Old Nov 12, 2023 | 09:11 PM
AK4x4's Avatar
AK4x4
I would recommend the Eaton truetrac, I really dislike the factory E-locker in my current truck. For on-road winter driving a limited slip diff is my preference with the true trac topping the list. Combined with traction control the truck will do anything I need/want. The e-locker is frustrating on icy roads, with it off you have a one wheel wonder going nowhere, and with it on a locked diff that doesn't like turns due to no differentiation. The owners manual basically says leave it off on road. I sure wish the factory would offer the true trac as an option. Good Luck, Russ
Old Nov 13, 2023 | 05:26 AM
HeavyAssault's Avatar
HeavyAssault
I'd suggest posting a pic of the 4wd dial on the dash. You may already have a factory Electronic Locking Differential (ELD).
Old Nov 13, 2023 | 11:45 AM
wheelerfreak's Avatar
wheelerfreak
The Sterling 10.5 should also be a 35 spline axle. Just about all the major manufactures make a locker for it, Eaton, ARB, Lock Right, and of course Ford.
Old Nov 13, 2023 | 12:05 PM
redford's Avatar
redford
FTE Leadership Emeritus
Welcome to FTE, Leo21.
The good news is that there are many limited slip and locking differential options available for the Sterling 10.5 differential. I would avoid the factory limited slip (if you find one in a salvage yard), they aren’t very good. All aftermarket units are superior.
The factory locking differential is OK. My only complaint is the truck computer automatically unlocks the differential above a certain speed, 8 MPH if my failing memory serves me well. Setting it up on a separate switch to allow you to have full control of the unit would work very well.
Old Nov 13, 2023 | 06:11 PM
Leo21's Avatar
Leo21
2nd Gear
Thanks for your help, doing a Google search I only found 10.5 for 35 spline, there is no one for 31 spline.
Old Nov 13, 2023 | 06:22 PM
twobelugas's Avatar
twobelugas
I haven’t engaged mine except when I really needed it to get going at low speeds. Does the factory e locker re-lock if the trucks slows back down?
Old Nov 13, 2023 | 06:33 PM
shawnee1's Avatar
shawnee1
It unlocks at speeds over 20 mph in 4x2 or 4x4 high modes and 56mph in 4x4 low. It relocks when the speed drops below those values.
Old Nov 15, 2023 | 08:15 PM
00t444e's Avatar
00t444e
I would go with a Detroit Locker, I have one in my truck and I love it, one of the best modifications I ever did. Strongest and most reliable locker on the market, the Yukon Grizzly locker is also good, same design just a different brand.
Old Nov 15, 2023 | 08:22 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Or you can put it on an upfitter switch and take the nanny out of it like I did. On or off any any speed.
drunkdave
1978 - 1996 Big Bronco
Sep 10, 2009 09:12 AM
mud rat jr.
1966 - 1977 Early Broncos
Nov 9, 2006 11:45 AM
fordman954
Offroad & 4x4
27
Mar 15, 2006 05:00 PM
F150newf
Sep 8, 2004 05:41 AM
patsplace
Offroad & 4x4
24
Dec 8, 2003 03:42 PM
