Sponsored by: Real Truck
Torque Shift problems
Old Nov 12, 2023 | 03:11 PM
RemingtonCG's Avatar
RemingtonCG
I have an 03 F250 with the 6.0, I had some transmission problems recently, and determined my transmission was bad. I know I should’ve had it rebuilt and that was the path I was going down but got talked into getting a parts truck and using that trans. Long story short it ran fine for a while but now it’s giving me some problems again it has a really hard shift from 3rd to 5th and sometimes it just put itself into fourth. It also takes 3 to 5 seconds to go into gear after I select drive or reverse, It is throwing the p02703 code which correlates to the transmission friction element D apply time range or Performance. If anybody knows for sure if it’s an actual hardware problem or if it could be an electrical problem please let me know. Thanks.
Old Nov 12, 2023 | 08:03 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
If it was an electrical problem you would have codes for an electrical problem. The codes for electrical problems are the most reliable codes that the PCM runs. If there is no electrical codes you do not have an electrical problem.
newapple
6.2L V8
Apr 21, 2012 11:46 PM
lakewood
Oct 7, 2011 08:18 PM
mikerans
Aug 8, 2011 09:59 PM
