Parking Brake Light? BCM?
Old Nov 10, 2023 | 08:36 AM
Flyrr100's Avatar
Flyrr100
4th Gear
Hi... New to the forums...
2010 F150 RWD 4.6 XLT.
My parking brake light is permanently on with the annoying chimes, which stop within 3-5 minutes. But with the light on my cruise control won't work. Greenaway Ford in Orlando say it's a bad BCM which they want $1800 to replace! There are no other electronic abnormalities. I've changed out the parking brake switch and it did nothing.
I'm looking for any ideas? Or if not, maybe a shop here in Orlando that can fix the problem for less that $1800!
Thanks.......,
Old Nov 10, 2023 | 08:34 PM
rbentnail's Avatar
rbentnail
I'd start with normal maintenance- lube cable, inspect brakes, etc. After that it's wire tracing.
Old Nov 10, 2023 | 09:19 PM
projectSHO89's Avatar
projectSHO89
If you want to second guess the dealership technician's diagnosis, you need to start by scanning the system to see what it's complaining about. Anything else is just guessing and hoping to get lucky.
The parking brake switch is only one of the several potential reasons for a constantly illuminated brake warning light. The brake fluid level switch is another. Those are the easy ones, after that it gets a lot harder and is going to be electrical/electronic.
78 f150 400
Mar 19, 2018 03:00 PM
jle70
Dec 15, 2007 12:08 PM
battleriver
Jul 23, 2006 02:29 PM
Thank you
Nov 4, 2004 11:32 PM
dalejarrettfan
Jan 29, 2003 01:54 PM
