To prime the oil system, use the 1/8" that is farthest one back (right in the picture) or the brass one on the oil cooler header above the filter. The middle one is coolant, the left one is a straight shot back into the oil pan.
I wasn't planning to rebuild this motor, ever. It had some blow by and used some oil at 200k. It had plenty of power and started easily. I lost a turbo bearing going up Vail pass towing my camper two summers ago. My exhaust housing was too big and the egts were too high for too long or it was a bad turbo. It ran for another 5k miles after replacing the turbo. I didn't take apart the short block but the engine pan had a bearing chunk and the lpop had bad metal scoring.
It was either rebuild the motor or sell the truck for cheap. I have a lot of work in the WVO system, suspension, tires, steering, bushings, bearings, brakes, ect ect... Tough choice but in the end I couldn't let it go to someone for a discount.
I bought the harbor freight 2 ton engine stand new for $200 and the harbor freight 2 ton hoist used on CL for $150. They were both strong enough and I felt safe. I should be able to get $250- $300 when I sell them. Its like renting them for $100. There are lots of engine hoists and stands in the used market at least in Denver. They are single use for lots of people.
Gotta be careful with the harbor fraught engine stands. lots of reports of the motors bending them in half over night.
Remember, our motor is 900something pounds dry.
They might have beefed them up now.
But. yeah. Not in my budget at the moment.
IF I pull it, i'ma wanna re-ring it. and.. i just dont have the money.
Correction. I used the HF 1 Ton Engine Stand so 2k pound rating. It spun the long block easily and it felt safe. If anyone is looking at one for a 7.3, I would recommend it.
Everything is buttoned up and the fluids are topped off. Turned the motor with the starter this afternoon. I did 12 second bursts with a long rest. On the fourth and fifth try it built 20# of oil pressure. Seems like the low pressure pump is working.
I checked the HPOP reservoir after the 5th try. It was full. I plugged the CPS in and tried to start it. Then my batteries died. They are Walmart batteries with a 6/17 date. It is a miracle they work at all.
So far it seems good. It took the correct amount of coolant and oil. No weird noises. Stay tuned.
The motor started after two 20 second cranking cycles. No funny noises or smoke. I only ran it for a couple of minutes. I will post up a video after I get the break in oil changed, the intake assembled, and the front end on.
Ok, I have 100 miles on the motor. I ran it with out load between 1500 and 2200 rpm for 15 minutes. The I did some 1500 to 2200 pulls in low gears and quite a few 1500 to 2200 pulls in first gear. I let it coast to a stop and downshifted instead of using the brakes.
It runs really good. There is no shaking at idle, it starts up nice, and is real smooth throttling up. It had a bit of blue smoke on startup this morning and it has vapors/ blowby. I have read it takes 10k miles to seat the rings on these.
Is it normal to have this amount of steam coming from the oil fill?
Should I wait till 500-1000 miles to change the oil? That seems like a long time.
I am getting nervous, starting to think the lack of comments is not a good thing. I was hoping for less fumes from the filler but the motor seems to be running good.
