Sponsored by: Real Truck
Speed Sensor A
Old Nov 6, 2023 | 06:33 PM
homertwo's Avatar
homertwo
Speed Sensor A
I have a 2001 F250 with the 5.4 engine. Automatic trans and 4 wheel drive. I am getting a code 500 that says it is the Speed Sensor A. I have changed all 4 of the sensors that I know about. The 2 on the front wheel hubs. The one on the top of the trans and the one on the rear end.
I keep getting the code and the OD light is blinking.
Which sensor is sensor A?
Thanks for any help.
Old Nov 7, 2023 | 02:31 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
There is no code 500 on a 2001. What is the real code you are getting? Is it P0500?
If it is P0500 that is for the vehicle speed sensor (VSS) on top of the rear axle. Since the new sensor didn't fix it, you most likely have a wiring issue between the PCM and the VSS.
Maustonmike
Apr 26, 2026 12:45 PM
Merlot913
Feb 17, 2024 10:13 AM
skyfox10
Modular V10 (6.8l)
Apr 14, 2014 08:06 PM
Muipekelo
Apr 5, 2013 05:24 PM
nanufree
Dec 19, 2005 12:33 PM
