Sponsored by: Real Truck
Oss
Old May 1, 2021 | 06:22 AM
Merlot913's Avatar
Merlot913
Oss
Output speed sensor
i have a 2011 f250 and can not locate the sensor . Any help please . 6R140 trans emissions
Old May 1, 2021 | 06:40 AM
Desert Don's Avatar
Desert Don
Originally Posted by Merlot913
Output speed sensor
Cuz there ain’t one. All in the tone ring/pickup for ABS built into the wheel hubs.
Old May 1, 2021 | 08:45 AM
Merlot913's Avatar
Merlot913
Osss
do you know what sensor needs replaced in order to fix it . Sending a p0720 code and one of the description is output speed sensor
Old May 1, 2021 | 09:20 AM
Desert Don's Avatar
Desert Don
You probably need an ABS / TC scan tool to isolate which it would be since there is a speed sensor on each wheel. Just my guess.
Old May 1, 2021 | 11:00 AM
Evan_P's Avatar
Evan_P
Incorrect. The 6R140 does have an output shaft speed sensor. It is located inside the trans and can be accessed by removing the transmission pan.
Old May 1, 2021 | 11:03 AM
Desert Don's Avatar
Desert Don
Well, crappo........I was wrong. First time in 75 years! LOL
OP, sorry about that. This guy knows more than I do about this, so listen to him, not me!
Old Jun 6, 2023 | 03:25 PM
Burger201267's Avatar
Burger201267
7th Gear
So Evan i got a 2012 6r140w need the input speed sensor is this behind the pan as well and easly accessable by pulling pan?
Old Jun 6, 2023 | 03:50 PM
Burger201267
7th Gear
Did you ever open the trans and find the sensor in you 6r140? And where the input and output in there?
Old Jun 8, 2023 | 03:46 PM
Evan_P's Avatar
Evan_P
I assume you are talking about the Turbine Speed sensor? If so yes, you have to pull the pan as swell as the main control valve body. With that out of the way it is bolted in , driver side of trans towards the front.
Old Jul 12, 2023 | 01:14 PM
Burger201267
7th Gear
I did on my 6r140 f250 6.7
The output is in the trans mission and is the easy one to get to
The input sensor is behind the valve body and will need to be removed to get to it all in all it was not that hard of a fix
there is a ypou tube video just look 6r140 transmission Curmudgeon transmission was the post i saw and show him with the trans on a table pulling the valva body off
Old Feb 17, 2024 | 10:13 AM
d00ley's Avatar
d00ley
5th Gear
did the OSS fix your 720 code? replaced mine yesterday on a 2014... still throwing 720. I see guys on here that have replaced plugs, wires, coils, batteries & cables trying to fix the 720... trying to find the next most reasonable step
Bkiggins
Feb 17, 2015 02:34 PM
Muipekelo
Apr 5, 2013 05:24 PM
s_herod
Jan 20, 2010 12:48 PM
nanufree
Dec 19, 2005 12:33 PM
JF1474
Aerostar
Sep 11, 2004 09:21 PM
