Wiring issues
Old Nov 4, 2023 | 10:47 AM
Tony Cappelletti's Avatar
Tony Cappelletti
Wiring issues
So when I tore my '54 F-100 down I found some old wiring, some new and some new modified wiring. I want to start new so I've been trying to locate a source that I can buy the wire I need based on the schematic in the book and measuring the lengths on the truck but I'm having a heck of a time finding where to buy. Most places sell wire in amounts that I will never use and I haven't found one that offers the various colors to match the diagram. Is my solution to buy a new harness? and if so where do I get it? Do they cover the entire truck or just under the dash and the rest is still up to me?
Still have to repair the rear fenders and the box but hope to have it back on the road this spring (if I can find some wire).
Old Nov 4, 2023 | 12:09 PM
abe's Avatar
abe
In 1999 I got a stock wiring harness from MidFifty. If you are not adding a lot of electric accessories this would work for you. Now they are going out of business. But there are others that sell something like this. All the wires are the correct length and are color coded.
Old Nov 4, 2023 | 02:23 PM
52 Merc's Avatar
52 Merc
There are several vendors that sell original type wiring harnesses made from factory blueprints with correct wire lengths and proper terminations. If your goal was to recreate a stock harness from bulk materials, as you noted, it's going to be tough to find anyone to sell you bulk wire in odd, custom lengths. Especially the old style fabric insulated type with all the stripes and colors that came from the factory. Your best bet will be to buy a complete harness kit from someone.
Shop around and do your research. Know what you're buying. Beware of cheap kits that use copper coated aluminum wire instead of true copper wire. If you see anything in the ads or descriptions that says CCA, run away quickly. If you're still running 6 volts, make sure your kit has the correct, larger gauge wire that's compatible with 6V instead of the lighter gauge 12v kits. Ask to know how complete their kits are. Depending on application, a lot of kits come in pieces; under dash, under hood, and rear harnesses, lighting and accessory pigtails, etc. Make sure you get all the parts to make a complete harness.
Old Nov 4, 2023 | 02:47 PM
abe's Avatar
abe
One more tip
If the current wires are in place don't rip them out all at one time. Tear out a little bit, put in the new, and so on. Use the old as a road map.
Old Nov 5, 2023 | 04:59 AM
FDV838's Avatar
FDV838
I had great luck rewiring my 50 F1 with a stock wiring harness from Chuck’s trucks in CT. All the wires are color coded and match the original harness. Very easy to install as someone already mentioned replace one harness at a time.
Good luck,
Tom
Old Nov 5, 2023 | 01:44 PM
ManFordman2's Avatar
ManFordman2
I found this on the Midfifty site.
Old Nov 5, 2023 | 03:37 PM
FortyNiner's Avatar
FortyNiner
Don't forget Rhode Island Wire: https://riwire.com/
Old Nov 5, 2023 | 04:52 PM
Doc's Avatar
Doc
I did the same thing when I re-wired my truck. It was $100 more than the EZ Wire, etc. systems. Best $100 I ever spent. Just plug and play like you said. Everything is already cut, crimped, color coded and ready to go.
Old Nov 5, 2023 | 06:20 PM
52Flthed's Avatar
52Flthed
I've heard several good things mentioned on various forums, about places like Rhode Island, Tyree Harris, Bauer etc. But I also happened to buy mine from Chucks Trucks, and it came with schematics, it was a great product. I really trust Chuck for the highest quality authentic parts that are available and good advice. It was all original type cloth covered wire but has the vinyl underneath that. It's a good idea to get that old stiff wiring replaced.
woodsmoke
May 15, 2015 11:09 PM
Cosette
Sep 17, 2011 06:26 AM
Customlover
Electrical Systems/Wiring
Sep 1, 2008 01:12 PM
munkee13
Feb 21, 2005 09:37 AM
